Miles on your 107" big bore kits.
Old Sep 29, 2012 | 11:37 AM
  #31
bagman1's Avatar
bagman1
Might as well go with the Timkin bearing while youre in there. I think the same way, strength, integrity and longevity. I spoke with my builder and he was explaining about crank flexation. The cranks will always scissor, the key is when they scissor, they need to return and the problem with pinned cranks is someday they dont return and that where the run-out screws everything up. The point of mentioning that was he says you dont need the timkin if you have a welded crank, but for less than $500 in P&L you would have a better sense of bulletproof.
Old Sep 29, 2012 | 11:56 AM
  #32
DBAGR's Avatar
DBAGR
Originally Posted by sergel
On my 2009 Classic, I am chasing an annoying vibration in the 2500 to 3000 rpm range which I am now convinced is comming from the crank. So, as a winter project, I intend to split the case and have the crank shipped to Revolution for a full service (plug, weld, true and balance...).
Naturally, while I am there.... might as well put it back together with a few goodies... As I am mostly a long distance rider and comfort/reliability is my first concern, I thought the Revolution 107 kit with its new (not re-bored) cylinders were the best choice out there. I like the idea of plated cylinders for better heat control...darn, all other motorcycle mfrgs have gone to that...the MoCo is probably one of the last ones still sleeving cylinders...
Thinking of simple build, TW555 cam, stock heads. With the welded and balance crank, this should yeald a pretty good long distance set-up I think...
Any thoughts? And I too am wondering about long term reliability of those juggs....
I did an upgrade on 88" two and half years ago using Rev Performance kit. Although the 98" kit used has a different piston pin setting, the cylinder bore diameter is the same as the 107 so the durability should be very similar. Did an oil change to his bike last week, so just for reference we did a leak-down test. With 31,000 mi it had less than 4% leak-down, which is better than 85% of the new bikes coming off the showroom.
Old Sep 29, 2012 | 12:08 PM
  #33
mgmmgm's Avatar
mgmmgm
107 builds :
Heads for that build, what is the best way to go?
Will be thinking 107 build in the future.
Would do Timkin and have crank trued, balanced, and welded.
Or, Maybe just toss a SE110 in the bike with some cams and be done?
Old Sep 29, 2012 | 01:53 PM
  #34
sergel's Avatar
sergel
That's pretty impressive... I like the idea of the plated cylinders. Did you see a heat difference?
Old Sep 29, 2012 | 05:35 PM
  #35
DBAGR's Avatar
DBAGR
It's not my bike so I can't say for sure, but he has never complained about it running hot.
Old Sep 29, 2012 | 06:18 PM
  #36
$tonecold's Avatar
$tonecold
As I said in a few posts earlier than yours, if you are going to straighten the crank, weld, plug, balance, and do left side Timkens, I'd get the cases bored and go 117 ci., especially if you're going to spring for the RevPerf cylinders for the 107. You wouldn't want to run stock heads, but if you're going this far that is not much more $. I would give Frank Drago a call and get his input. With the 117" you would always have the torque for any situation!
Old Sep 30, 2012 | 01:07 AM
  #37
papifun's Avatar
papifun
Serg...where you getting your 107 build done in Mtl?
Old Sep 30, 2012 | 04:05 AM
  #38
CigarCritic's Avatar
CigarCritic
2008 HQ 107 with 36,000
2011 FM with 13,600
Old Nov 11, 2012 | 05:39 PM
  #39
Dwayne Regur's Avatar
Dwayne Regur
Stage I
I did an Axtell 107 Kit and beat on it all summer at the dragstrip with no problems I suggest an HPI 55 Throttle Body along with it. Getting ready to do a NOS kit now.
Old Nov 11, 2012 | 06:36 PM
  #40
ultra5516's Avatar
ultra5516
Dam I'm doing 106" S&S build just in parts I'm at $4,700 and I still have to have the heads machined for the acr's, valves and ported, timken bearing sleeve installed and then send the new S&S cyclinders and heads for the diamond cut and have the heads re-powder coated to match cyclinders I'm hoping this engine runs really well LOL
