caliper bolt size
"Does any one know the size of bolt and thread pitch that a 02-06 road king front caliper? The bolt that holds the brake pads in place. its ike a 8mm socket. The threads on my caliper stripped and i want to repair them."
You're not going to find those at the hardware store. They are not just a typical bolt. The best bet is to go to H-D and order a new set. (It's like $10 for a set.)
If you just need to tap the caliper to clean up the threads, just measure the threads on the the pins to determine threading.
Also, they are not 8mm head; they are 1/4" 12-point. That way he won't mess up the head next time he's working on it.
