Removable Wheel Chock
Old Sep 30, 2012 | 09:22 AM
StreetKing's Avatar
StreetKing
Default Removable Wheel Chock
Signing papers on a Toy Hauler tomorrow.Getting into that retirement out west mode. I got a hauler that doesn't have the seperate garage area. You flip up the couches and put the bike in. What I'm looking for is a chock I can remove so I don't bust a toe. Thanks
Old Sep 30, 2012 | 09:33 AM
Handlebarmike's Avatar
Handlebarmike
Check out Pingel....they got some that should work well.
Old Sep 30, 2012 | 10:37 AM
mariner227's Avatar
mariner227
I mounted a cheap Pingle chock on a piece of 3/4 inch plywood with large washers. I've lent it out to people who have used it in the back of pick ups and trailers. Slide the plywood in and out when needed. You do not have to use a full 4x8 Peace of plywood to make it effective. You do need the plywood to butt up against something solid to make it effective.
Old Sep 30, 2012 | 10:47 AM
Chunker's Avatar
Chunker
I have a separate garage, but also wanted to be able to remove the wheel chock to have a flat floor. Had an aluminum bracket made to bolt the HF wheel stand chock into and the whole affair can be lifted out and moved to the side or out the back. If you went the "mounted on plywood route" then if the wood was on or over a tie down ring, cut a slot like in my pictures to secure it and keep the whole thing from moving.
Attached Thumbnails Removable Wheel Chock-001.jpg   Removable Wheel Chock-005.jpg
Old Sep 30, 2012 | 11:34 AM
NDBadlands4-2's Avatar
NDBadlands4-2
We just bought a toy hauler this summer too. It has two removeable Pingle chocks and they are an easy in and out and function very well.
Old Oct 1, 2012 | 05:03 AM
StreetKing's Avatar
StreetKing
Thanks guys for the info. I like that Pingel set up.
chevy406
General Topics/Tech Tips
Mar 26, 2017 06:57 PM
Gaddis7
Sep 5, 2016 08:34 AM
jenkinsjj
Jul 26, 2009 09:43 PM
jeg1
Jul 17, 2009 11:52 PM
brendajm
Mar 27, 2009 09:17 AM
