switch housing
Old Jan 29, 2007 | 03:00 PM
ACRoadKing's Avatar
ACRoadKing
Default RE: switch housing
I just did mine this past weekend when I changed my bars. I think retail is something like $134.95. I got mine from Zanotti's for $105.94.
Old Jan 29, 2007 | 03:16 PM
Manish_Hawg's Avatar
Manish_Hawg
The current price for the switch housing is $123.95. I will pay half that price and it will look just as good if not better.
Old Jun 17, 2007 | 09:19 PM
lourvg's Avatar
lourvg
1st Gear
In the manual there is a note that if you don't use the spacer behind the brake lever it says that the plunger from the master cylinder could be damaged
Old Jun 17, 2007 | 10:49 PM
gman's Avatar
gman
just in case someone with handlebar turn signals reads this thread, you will have to either cut or un-solder and re-solder the turn signal wires since they go through holes in the housing. The non-handlebar mounted lights, like on the UC, RK and others, are much easier to do since you don't have to cut any wires.
On both however, patience is the word!! I've done it twice, on my WG and my UC. A pain, but does look real good when you get done.
I bought my covers on E-Bay for around $60.
Desert wind
May 26, 2019 02:44 PM
LKHA
2014-2024 Touring Models
Dec 29, 2014 09:25 PM
oldtimer59
May 17, 2007 01:18 AM
hbski
Dec 13, 2006 08:21 PM
