new rider seeking advice......
Novice: "A person new to a field or activity; a beginner"
The mileage on the bike you're looking at is some crazy mileage. Good on the original owner to ride that much. Not so good for the buyer.
Old geezers riding motorcycles for the first time scare me just about as much as pimply skinned 17 year olds and they give the rest of us just as bad a name. Listen - you've gotten some pretty good advice here. Whether you choose to accept it is up to you. It's no skin off my back - but it just might be off of yours. Be safe - don't assume anything. Work your way up. That's my opinion and you're entitled to it.
I bought a 2004 Vulcan 750 because it was cheap. I am so glad that I hit my first wet road paint, gravel, oily spot on that bike and not my 2003 FLHTCUI.
I bought my FLHTCUI last year after 7 years, 20k on the Vulcan. Like Bronson says, your first panic stop on a 950 lb dresser,it is easy to lock up and skid out the rear. I did it twice, and it is scary.
So you can follow your heart, or use your head. If you want a Harley get a Dyna before moving up to a FL.
First bike, 500 lbs.
Current bike, have 17k miles in 2 seasons, and took the Skilled Rider Course on it. 950 lbs, handles great, but still a handful at low speeds, on gravel.
It isn't a good bike for a beginner - hence the other suggestions.
- Take a MSF course
- Make sure your insurance is good
- Read the sticky with the video of how to pick up a Harley.
- Wrap the bottoms of your engine guards and bag guards with rubber hose (Garden hose will work)
- Keep friends around who will help you pick up your bike
- Stay out of heavy traffic areas until you are used to the bike
- Enter highway corners slower than you think you should
- Don't try to keep up with people if you have to get out of your comfort zone
I never felt like the bike was too much for me, but I did drop the bike a few times with the engine guard getting a few scratches. The bike is heavy just sitting there, but light as a feather once you get moving.
If you do a lot of parking lot practice, then the bike itself will be no big deal on the road. In fact I think the bigger bike is easier to ride on the road. But the key to getting used to the size and weight is the very slow riding in a parking lot.
Beary
I practiced the following on the street with mine shortly after getting it (I still do practice these and plan to continue doing so):
- Cornering until I was at the point I could scrape the floorboards on purpose
- Braking in the corners so I knew how the bike would react (The worst time to learn cornering is when you find yourself coming in too hot)
- Stopping by picking a spot to stop at each intersection
- U turns
- Riding in formation
- quick stops with both brakes (Threshhold braking)
- acceleration (When to shift down for more power and how fast it could accelerate away when needed)
- quick swerves (counter steering)
- road position based on traffic
- etc. (Basically I try to think up every street maneuever I might need fast and then practice it so it will be natural if I ever need to use it)
I also spent around 8 hours broken up over four days practicing parking lot skills using skills test diagrams found on the Internet. I cut the tops off water bottles to use for cones to set these up.
These included:
- cone weave
- quick stops
- swerving
- u-turns
- and curves based on the new test procedure in this state (Washington is the first and only state so far to adopt the new MSF curve test)
The parking lot practice and practicing in corners on the street were the two things that I feel did the most to put me in synch with the bike. The practice earned me compliments by other riders (all with smaller bikes) and by the instructors when I did take the skills test using my Heritage (Had to do so since I never transferred my endorsement after I got out of the service).
After the above I now feel like I understand the bike and it understands me. I will still practice though and plan to take the Experienced Rider Course next spring when it is available. (I plan to ride as much as possible between now and then unless there is ice or snow on the road) I'll be encouraging any of my family members that decide to get bikes after taking the novice class to take the experienced class at about 6 months of experience riding too. (The advanced rider class too if it looks like they need it first)
