Push Rod Spring Clips####
Old Oct 6, 2012 | 02:39 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Push Rod Spring Clips####
OK, what's the trick to get the spring clips on the push rod tubes without turning red and yelling every name in the book.....
Cam jobs done, adjustable push rods are adjusted and these clips are trying my patience big time....
Old Oct 6, 2012 | 02:52 PM
scotracy's Avatar
scotracy
Do what I do... have your Indy help you out when you get into a bind. Mine always helps me out!
Old Oct 6, 2012 | 03:03 PM
dawg's Avatar
dawg
Use a screwdriver and your finger and "walk" them into place.
Old Oct 6, 2012 | 03:08 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Sounds easy...NOT.....what goes in first, top or bottom???
Old Oct 6, 2012 | 03:12 PM
dawg's Avatar
dawg
Okay, let me see if I can explain this. Put a flat blade screwdriver on top of the bottom tube and push down while sliding your finger forward toward the bottom of the screwdriver and pushing the clip into place.
Old Oct 6, 2012 | 03:18 PM
StevieRay59's Avatar
StevieRay59
Ya what he said. Push the top in first, hold it as tight as you can and pry the bottom in with a flat blade screwdriver. Just did mine and yes they are a PAIN ha!!
Old Oct 7, 2012 | 11:37 AM
HDV-GLIDE's Avatar
HDV-GLIDE
With Dawg's instructions, they just about fell into place......Thanks for the info.....
sjbodie
Engine Mechanical Topics
Dec 31, 2014 12:33 PM
swhitinger
Nov 5, 2013 04:27 PM
jgwoz
Aug 2, 2012 01:41 PM
krh1326
Aug 13, 2010 10:15 PM
sneeky7374
Shovelhead
May 3, 2010 08:23 PM
