Tuning The 120R
Now, I'm still running the stock head pipe, gutted and CVO slip-ons with 1 3/4" Fullsak baffles so I'm thinking it's not going to be able to breath as well as I want so I don't want it to be a blubbery mess so I left it as is for the initial start up.
It would barely idle! The base maps are extremely lean! I've added fuel four times now and every time the bike responds positive to the changes.
Any of you 120 owners had the same experience?
btw, even with the restrictive exhaust, the 120R has it all over my stage 4 113 I had last year.
Not saying I haven't tried this before but as long as you're not above the VE table's max percentage (I'm not close), it's just an easy way to richen the tune.
As lean as the base map from Harley is, I'd say running it up to 138" would get it in the ball park.
I did not like all the flat spots throughout the rpm range (only taken mine to 4500 rpms so far) so I tuned them out of it.
Surprised at the difference between the base map front and rear cylinder VE tables; looks like you're working on two totally different engines. I duplicated my front cylinder to the rear then raised the rear cylinder 5 full points on the VE table.
The bike now idles smoothly (as smooth as 266e cams can) and I can pull away from a stop just as easy as with the stock 103.
Two other things I did not like about the 120 base map:
1. the idle was too low; below 950 rpms. I want mine right at 1000
2. temperature/idle settings were kind of screwy; I guess that had to do with idling the engine that low.
How loud was the Dragula before you supercharged it?
I cannot stand an excessively loud bike. I had a Boarzilla on the 113 and it made riding the bike a painful experience so I will not do that again.
