The red key light
Also I have heard of problems with the light staying on with when running the Kuryakyn Run Turn Brake controller. They sell a different "security compatible" voltage regulator for those that have the light come on and stay on. It doesn't affect anything, but the light can annoy some, so that is their fix.
Right after you turn your Ignition to on with your speed odometer push button pressed, release earlier and you should see PSSPt, (your letters will vary, write them down).
To answer your question about Security, when the computer of our bikes are turned on it performs a system check each time so when we see these lights come on the computer is checking ALL when it is turned on.
Do not see PSSPt.
Do not get "diag".
All I get is codes d01clr, d02clr, d03clr.....d10clr.
Then "PPU"
Then that number mentioned above, which according to the dealer is the ECM number.
When I switch the ignition ON, the engine light and security light come ON. Then they both go out, and after that if I hit the start the bike, the security light comes back on again for about 8 seconds, then sometimes goes out.
Last week this was not happening after staring, but, then after I disconnected the battery and/or hooked it up to the battery tender, the security light started coming on after the bike is started.
Sometimes it stays on, other times it goes out after 8 seconds. I thought the FOB battery was going bad, so I replaced it with a new battery, same thing.
I tried the "rest" method, i.e. hold the reset button in for longer that 5 seconds until I see Clear....and nothing happend. So presumably I have no codes to clear.
Yes, the freeking red light, warning me of an eminent breakdown due to an unknown security issue in the middle of nowhere is concerning and irritating the crap out of me. Not knowing if it will re-start after gassing up, for example.
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Turns out there was a code, something about the accelorometer, tilt indicator and TSSM (Turn Signal Security Module) going bad.
Just ride it like that, and ignore the light they said.
Or, I could get a new TSSM,
Or eliminate the security system and just get a TSM.
