What would YOU do?
Old Oct 13, 2012 | 08:34 PM
Gliden's Avatar
Gliden
Default Wwyc
[QUOTE=Pioneer74;10441041]How long since you last rode it?[/
4 days.
Old Oct 13, 2012 | 08:35 PM
Gliden's Avatar
Gliden
Originally Posted by mdp
Believe or not, same thing happened to me. I know no one let the air out and the garage is locked. It's been holding air for 2 weeks now but I am paranoid as hell.
That's crazy. Do you have spoked wheels like this?
Old Oct 13, 2012 | 08:40 PM
Pelonz's Avatar
Pelonz
Re-seat the valve stem (loosen the shrader valve and re-tighten it a couple of times). Ride it a while and re-check pressure.
Old Oct 13, 2012 | 08:41 PM
j1mmy's Avatar
j1mmy
sometimes the valve core/schrader valve just bounces or doesnt seal rite. a cheap valve cap can sometimes let the air out if the core is high in the valve.all i would do is make sure the core is tight and not leaking.. it is rare, but happens. if it holds air for a couple days,it isn't going to leak.
Gliden's Avatar
Gliden
Originally Posted by K Melancon
Had the same thing happen once. I had cleaned my bike and check tire pressure the day before my ride. Got ready to leave early in the morning and tire is completely flat. Pump it up and watch it for a week and never lost pressure. I think when I checked the pressure that the schrader valve didnt seat back closed and let the air escape.
Man........that's actually conceivable . Lol
Well I'll let you guys know what I find in the am.
A low tire today and I wouldn't even care. Seeing this thing 100% flat bothers me. Thanks for everyones input. Ttut
Old Oct 13, 2012 | 08:43 PM
Gliden's Avatar
Gliden
10-4 will do this in am..thanks
Old Oct 13, 2012 | 08:45 PM
Gliden's Avatar
Gliden
Ok Jimmy. My freak is subsiding now that I see some of you guys have seen this too...lol
Thanks bro
Night,
Old Oct 13, 2012 | 11:18 PM
Devo6684's Avatar
Devo6684
A short story-
Could be a broken shraeder(sp?) valve. Over a month ago I checked air in my front tire with a gauge and the air kept coming out the stem. Added more air with my compressor and it stopped. Held air for well over 600 miles.
A month later I check the pressure again before a trip to Tennessee and again, the stem leaks air- this time adding air with the compressor does not work. I am pissed! I slightly overfill the tire and put on the valve stem cap and the leak stops! It holds solid all night!! It is now morning and I figure I will head to my dealer to get it checked.
I get a mile from the house and it goes flat. Called the dealer, they pick up the bike and find that the valve is broken.
For peace of mind and safety reasons I would have your valve checked/replaced. My .02.
Old Oct 14, 2012 | 02:24 AM
Duke 07's Avatar
Duke 07
The valve cores can go bad or get stuck. You can pick up a core tool and pop a new one in fairly quickly. I would say less than 5 minutes. Sounds like a few core issues IMHO. Good luck.
Old Oct 14, 2012 | 07:30 AM
RBWIDE's Avatar
RBWIDE
Originally Posted by Gliden
im going to go get a tin turkey pan and do that tomorrow....does anyone have any suggested preference of what kind of soap I should spray this tire down with to see a leak or any soap mix should do?
Cut it out, man. You're killing me. Of course *everyone* knows you have to use HD approved soap for it to be an approved HD leak test with no tire warranty implications.
