What would YOU do?
Old Oct 14, 2012 | 07:44 AM
William The Red's Avatar
William The Red
I have been told just use 409 you don't need a pan.
Old Oct 14, 2012 | 07:51 AM
piper59's Avatar
piper59
Dishwashing liquid works good.Put some water in a cup or bowl & mix with dishwashing liquid.Take an old paint brush & swab it all around your tire.If it's leaking anywhere you'll start seeing bubbles growing.
Old Oct 14, 2012 | 08:55 AM
ATL-HankO's Avatar
ATL-HankO
Default Another Option
Just to give you another possible issue. My Ultra (with Limited chrome front wheel) kept losing air. Turns out the chrome on the INSIDE was flaking and not allowing the tire to seal properly. It took me forever to find the slow leak, had to replace the wheel and now, all is good.
Old Oct 14, 2012 | 09:52 AM
Prodriverdon's Avatar
Prodriverdon
LMAO, Dont forget the receipt from HD for the " HD Leakfinder " soap..
Old Oct 14, 2012 | 10:00 AM
Pondskipper's Avatar
Pondskipper
+1 on the valve core.
Old Oct 14, 2012 | 10:25 AM
TUCCI's Avatar
TUCCI
I knew a guy who was fed up with the odd angle of the valve stem so he put on chrome angle tips which sounded like genius to him.......until after a few thousand miles becuz of the rotation of the wheel and the weight of the metal stem causing the rubber valve stem it was attached to break the seal loose leaving him stranded by the side of the road.. moral to the story......dont extend rubber valve stems with metal stems unless you have AAA or a buddy to help you out and will laugh at you with comments like hummm if you had a Harley that wouldnt have happened LOL.
Old Oct 14, 2012 | 11:47 AM
Gliden's Avatar
Gliden
Originally Posted by RBWIDE
Cut it out, man. You're killing me. Of course *everyone* knows you have to use HD approved soap for it to be an approved HD leak test with no tire warranty implications.
Oh yea forgot!
The reason I asked is there are some that are better than others. My dad had some stuff used by the power company special to find the smallest of gas leaks...it would bubble no matter how slight the leak.
Btw I got up this am and she was empty again.
I'm going to store for a new valve Thimbu that screws into the stem and a big tin to fill with water to lower the wheel into to try and figure this out.
I have laced wheels so I guess a spoke could have damaged the tube in there.....
Old Oct 14, 2012 | 11:51 AM
Gliden's Avatar
Gliden
I actually bought one of those right angle thingys but I don't leave it on there for that reason. I use it to fill then I unscrew it.
Old Oct 14, 2012 | 12:31 PM
Gliden's Avatar
Gliden
William I sprayed the valve stem with spray 9 and immediately saw air leaking out from under the jam nut that locks the stem in place. I have a tube so it's leaking inside the tire and pissing out the stem neck not the stem valve.
Thanks for the suggestion and I'll post back after I get the wheel back to let ya all know what caused the tube to go bad. Thanks again everyone for all your input.
Old Oct 14, 2012 | 12:50 PM
RANGER73's Avatar
RANGER73
That rubber band that insulates the back of the spokes from the tube may have shifted.
