Security system - motion alarm question
Old Oct 18, 2012 | 08:48 AM
PanJH's Avatar
PanJH
Originally Posted by Scotty.ie
It appears I have the same system on my 2002 RK classic. Is it a good system as in does it give trouble ? Also mine self arms after 30 or so seconds when I turn off the bike. Can I disable the auto arm on it ?
Here's what the manual says about turning off teh auto-arming freature
  1. turn ign switch on-off-on-off-on-
  2. Press left turn signal 2x - you should get 2 or 3 flashes of the turn sigals
  3. Press and hold Key FOB until you get confirmation - 1 flash of the turn signals
  4. Press and hold Key FOB until you get confirmation - 2 flash of the turn signals
  5. Press left turn signal once - this should show 2 flashes of the turn signals to indicate auto-arming is enabled.
  6. press left signal once -- should get one flash of the signal to indicate auto-arming is disabled
  7. Turn ignition off
phxlab
Sep 21, 2019 08:19 PM
Kevin714
Feb 29, 2016 02:33 PM
etxabier
May 27, 2013 08:42 PM
KiloGolf4
Aug 26, 2012 06:10 PM
DensFLH
May 21, 2006 09:31 PM
