03 roadking sputter
Old Oct 19, 2012 | 02:40 PM
harleyrk50's Avatar
harleyrk50
5th Gear
Default 03 roadking sputter
I have an 03 roadking classic. At around 60 mph, I hold the throttle steady and the bike sputters. I clalled local HD dealer and they want around $100 for a fuel filter. Before I spend the hundred, anyone got any other advise?
Old Oct 19, 2012 | 02:56 PM
mkguitar's Avatar
mkguitar
could be after 10 years you need a fuel filter, and possibly internal lines- no real surprise there.
when sputtering at 60, what happens if you whack open the throttle ?
more sputtering might indicate a fuel delivery problem...less sputtering or smoother operation might indicate the problem is elsewhere...spark timing which could be a crank sensor or other.
note the rpm at which it "sputters" what happens at that rpm in another gear?
IF you are headed to a shop to have them do the work, the more detailed your observations, the better chance they have of fixing.
Do not say 'change the fuel filter.." do say "at XXX rpms, my bike does XXX..."
Mike
Old Oct 19, 2012 | 04:01 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
When I had 5 Harleys they all sputtered...a bit.
NowI have 4 (one new) and they sputter too, but I know it's a matter of how bad the sputtering is.
How does your bike run under full throttle?
If it runs good at full throttle you're getting enough gas to run at cruising RPM's.
On my 2000 Ultra the sputter was especially bad so I tried fuel additives, sparkplugs, spark plug wires, a/c filter, intake seals, and a new TPS.
I gave up and took it to an indy.
Final solution was a new Engine Temperature Sensor, a new ECM (expensive) and a Stage II download.
Good luck.
Old Oct 19, 2012 | 05:54 PM
scrawfordFLSTC's Avatar
scrawfordFLSTC
I have a 2002 rkc. it started out with an occasional sputter, and progressively got worse until it wouldn't run at all. it ended up being a broken wire on an injector. check your injector wires.
Old Oct 19, 2012 | 07:12 PM
Pumba11's Avatar
Pumba11
I love my carb! No sputter ever!
Old Oct 22, 2012 | 09:12 PM
harleyrk50's Avatar
harleyrk50
5th Gear
Thanks everyone for their advise. A friend suggested Star Tron additive and it seems to have stopped the sputter. I hope it continues to be the answer!
FastHoss
Oct 9, 2018 06:32 PM
Mcoop
Aug 1, 2016 11:04 PM
whatzleft
Jul 18, 2014 09:58 PM
WOS Bishop
26
Jul 22, 2012 07:34 PM
Scubba2
Jun 29, 2012 09:03 AM
