I'm sure this has been talked about many time, but since I'm new to the forum I thought I would ask.
The previous owner told me the idle on my stock 88ci bike should be above 900 rmp's, or the oil pump won't work fast enough and starve the engine. He had the idle at 1100, which IMO was way to fast. I moved it down between 700-800 and it sounds good.
Anyone know if it will cause oiling issues being so low?
oil is part of the cooling system, not only does oil move through the hottest parts of the motor and carry away heat to be dispersed to the air, but the oil is sprayed at the undersides of the pistons.
ALL of the rotating motor parts are held by bearings or bushings- there is meant to be a thin film of oil in there for all these parts to float on.
the "traditional" harley sound was a product of a completely different motor design, which although appearing much the same has almost nothing in common with the twin cam
mike
