Trailering question
Old Oct 24, 2012 | 02:50 PM
jimsflh's Avatar
jimsflh
Originally Posted by JerryS63
These are what I am looking at currnetly:
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Show a 900lb breaking limit. Is this enough?
If they are re-enforced, and you are using a wheel chock, I'd think that'd be fine. just my opinion though.
Old Oct 24, 2012 | 02:52 PM
Scrmnvtwins's Avatar
Scrmnvtwins
I always go around the down tubes and the crash bar and have never had an issue with damaged powdercoat on the frame.
Old Oct 24, 2012 | 02:54 PM
VinnyM's Avatar
VinnyM
Thanks!
Old Oct 24, 2012 | 02:57 PM
Scrmnvtwins
I'll piggy back the thread. How much weight rating should you have on your tie down points? THe D ring setups I was looking at for putting in the floor of my utility trailer were only ratted 300lbs. I was a little suprised. I am trying to not put just screw eyes in the floor. THe D ring setups I was looking and flip flat for low profile when not in use. I have side boards on the trailer so tieing down to the top rail is not an option.
I would try to stay at least above 1500 lb....as most times you need the hold down is simply holding upright but....when someone cuts you off and you take the trailer for a ride through the ditch you most likely will be exercising the rating of the tie down. Check these out.
http://www.uscargocontrol.com/Ratche...ting-5-000-Lbs
Old Oct 24, 2012 | 03:02 PM
VinnyM's Avatar
VinnyM
This is what you want................and they sell backing plates for underneath. I use them in my enclosed and also on a flatbed that I carry a small tractor on.
Old Oct 24, 2012 | 03:41 PM
JimmyDee's Avatar
JimmyDee
Trailer has 2x10 flooring so those would not work unless I cut a recessed spot in the wood.
All you need to do is bore a hole and you are set to go. I have done 2 trailers with these type tie downs and they work great. I got a sheet metal shop to cut me some 8 x 8 x 3/16" plate steel for the backing plate.
Old Oct 24, 2012 | 05:04 PM
TURQ's Avatar
TURQ
+1 For years on my Heritage. On my SG I have the HD tie down bracket kit and it is the way to go on baggers. part #93500006
Scaredofrain
Powdercoat & Paint
13
Nov 22, 2012 08:33 PM
98glider
Ironhead
Nov 7, 2010 08:30 PM
sporacer
Nov 8, 2008 11:56 AM
BadPiggy
Jan 7, 2008 12:18 AM
BuckeyeFanInFL
Ironhead
Oct 30, 2006 03:47 PM
