Tires,
Old Oct 24, 2012 | 07:11 PM
EGBAGGER's Avatar
EGBAGGER
Stage I
Default Tires,
What's the biggest tire I can put on my 2001 Electra Glide Classic without any modifications ?
Old Oct 25, 2012 | 05:23 AM
grbrown's Avatar
grbrown
Cool
H from the UK and welcome to HDF. That question comes up often!
There are two limitations, rim size and belt clearance. Your stock tyre is an MT or 130/90 and the alternatives that we can fit on a stock 3" rim are MU85, which is 140/85, also a 150/80 will fit. They are all pretty well the same rolling diameter. Some brands sell a 140/90 which will also fit, but is a little larger in diameter.
That deals with rim size. Different tyres vary in fitted width, but you should find a 140/85 and 140/90 will go in, although it may be necessary to trim the rubber curtain on your belt guard. The Avon 140/90 gave me only 3/16" clearance between belt and tyre!
So with no modifications, your MT is all you can be certain of fitting. An MU will fit, but may need minor adjustments. A few have successfully installed a 150/80, but you need to be lucky or very determined to get one in.
Old Oct 25, 2012 | 06:18 AM
Notgrownup's Avatar
Notgrownup
I like that Graham...(Very determined) LOL...you mean mallets, grinders and hacksaws....
Old Oct 25, 2012 | 06:23 AM
grbrown's Avatar
grbrown
Talking
It would be possible to write an essay in reply to the OP's question, may even be possible to earn a PhD! We'll see if we get any follow up questions. I'll save installing my 4.5" Deuce wheel and 160/70 tyre for later.....
Old Oct 25, 2012 | 09:53 AM
lazybee's Avatar
lazybee
I asked the exact same question over on the tire section a couple of days ago. I think our friend from the UK is the tire guru for sure. I've been running the stock size Avon's with a narrow white stripe, but Avon has discontinued that tire. Looks like to get the narrow white I got to go with the Metzler. So, I think I'll pull the trigger on the MU85. For insurance I may go ahead and get a rear spocket spacer. The one from Pingle is about 60.00, but Vulcan has one for 13.00. Don't know why the big difference in price, but both are described as being used on 2000-2003 FLH models to allow for up to 142mm wide tire.
Old Oct 25, 2012 | 10:02 AM
frog13's Avatar
frog13
First, Welcome to the forum!
Second, in the spirit of this forum, as big as you want as long as you don't exceed the weight limit on the tour pack when you strap it on.
HEY! You didn't say where you wanted to put it on your bike!
Again, WELCOME to the forum!
I think grbrown did a great job of getting you a "real" answer.
Old Oct 25, 2012 | 10:03 AM
grbrown's Avatar
grbrown
Cool
lazybee, I've been doing this for a long time! I've used MT, MU, 150/80 and now 160/70 on my 1990 Glide......
Old Oct 25, 2012 | 10:11 AM
Pumba11's Avatar
Pumba11
On my '99 RK I can get the MU and 140 in without mods and have used them for years. But a 150 or 160 no way.
Old Oct 25, 2012 | 10:29 AM
grbrown's Avatar
grbrown
Talking
They can be done, but only with a little 'determination'! Not for beginners.
mac777
Feb 28, 2013 07:08 AM
killbee
Wheels/Tires
Oct 11, 2012 06:28 AM
markkenn
Wheels/Tires
Aug 31, 2012 05:38 AM
jamiefixit
Oct 4, 2011 04:01 AM
cdesero
Nov 25, 2009 07:04 AM
