Help with spark plug reading
Old Oct 29, 2012 | 12:20 PM
iclick's Avatar
iclick
Originally Posted by Neopheous
Ok. I'll give that a check although I've never noticed it before. Thanks.
A puff of smoke when starting either cold or hot would indicate a bad valve guide, and judging from the appearance of your darker plug you have oil slipping by either the rings or guides on that cylinder. I agree that a compression test would be a good idea, and since it's a TBW bike you'll have to remove the AC and hold the throttle blade open with a block of wood or something else that won't get sucked into the intake. If you have ACR you'll also have to disable that by disconnecting the TCA connector on the induction module.
slvrscoobie
Engine Mechanical Topics
Apr 21, 2016 06:45 PM
GibsonSG05
Sep 11, 2013 02:52 PM
N2STUFF
Apr 28, 2013 01:44 AM
justgliding99
Exhaust System Topics
Nov 25, 2010 08:30 PM
justgliding99
Nov 25, 2010 08:27 PM
