Harley Battery?
Old Oct 30, 2012 | 07:22 PM
fltr/fxrs's Avatar
fltr/fxrs
Stage I
Default Harley Battery?
I heard that Deka is the company that makes Harley batteries - was wondering if the battery made for Harley is any different than the one they sell on their own? I've had good luck with Harley batteries - but I can get a Deka for quite a bit less money - don't want to do it if the battery is not as good - also if there is another battery that anyone has used with as good or better results than the H-D battery please let me know -
any feedback would be appriciated - FXRS
This battery would be for a 2001 Raod Glide
Old Oct 30, 2012 | 07:29 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
deka makes hd and several other brands,u cab get em at pep boys, batterymart.com,batteries plus.and save a few $.same batteries with possible having slightly different cable mounts for universal fit.
Old Oct 31, 2012 | 02:51 AM
jjnoble's Avatar
jjnoble
Buy the deka.
Old Oct 31, 2012 | 04:02 AM
Scaredofrain's Avatar
Scaredofrain
Would Deka not build the HD battery to HD spec's where as their normal ones are more generic? Are the sizes the same, the pole positions and sizes?
Old Oct 31, 2012 | 05:46 AM
danny54's Avatar
danny54
Yuasa makes the best motorcycle battery out there.
Old Oct 31, 2012 | 06:06 AM
Notgrownup's Avatar
Notgrownup
I have had a ETX30L Big Crank from Battery Mart.com for about 2 years now...I think i paid $89 shipped...I am pretty sure it came in a Deka box. I woud buy it again.
Old Oct 31, 2012 | 06:12 AM
Terrabella's Avatar
Terrabella
+1 on that. I have the same ETX30L and it has been great.
Old Oct 31, 2012 | 07:49 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Another +1 on that......
Old Oct 31, 2012 | 08:20 AM
btsom's Avatar
btsom
The idea of Deka making the battery to Harley specs is an interesting thought. I have seen batteries made by Johnson Controls vary greatly in their dependability. Original batteries in Fords seem to go for at least 5 years, had an Autozone battery go for 2 months less than the 8 year guaranty, thought that was excellent, another of the same type died in 3 years. I have tried a couple WalMart batteries (also made by Johnson Controls, I am told) die in 14 months. Gave up on those after the second one.
Having read about failing batteries taking out the stator and voltage regulator during the slow failure phase I replaced my factory Harley battery at about 3 years because it was having trouble getting through the first compression stroke especially on hot starts. The Big Crank (Deka replacement) seemed good at the beginning but sooner than I realized, it began having trouble getting through the first compression stroke. When I finally put a volt meter on it during the start the voltage dropped to 7.6 during the first revolution. The battery had been in use for 15 months. The extremely favorable reviews in here made me suspect I had gotten a rare bad example so I bought another one. I just installed it and it spins through the first stroke with ease, hot or cold and maintains over 10 volts through the first revolution. Time will tell if it maintains this performance longer than the other one did. MOST Harley factory batteries seem to go at least 3 years yet one example of the "same" battery didn't make half that time. Are they really the same inside? It would be nice to get the straight story from someone who is knowledgeable and trustworthy (not trying to sell one battery over another). If the two batteries really are the same, selling one at almost twice the price seems almost criminal. Buyer beware.
For those wondering, I made all the voltage, stator checks and clean tight connection checks prior to each battery replacement and during periodic maintenance..
Old Oct 31, 2012 | 08:29 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Check the born on dates, buy fresh.
