What did you use for a kickstand??... mine sits way up straight with the burly kit on and a good wind could blow it right over... Len
Originally Posted by Ray Lloyd
Good luck with the install. I lowered mine 1 inch and am very happy with the bike. I can get my feet perfectly flat on the ground now, and can back up the bike a little easier.
My knee draggin', footboard scrapin' days are behind me, and I have noticed no issues with anything dragging.
when i put lower shocks on my RK it sat up to straight so i bought this kick stand wedge kit from drag specialtys that goes under the kick stand mount to change the angle . it was less than $50
On a 2012 the kickstand mount is different.. it's part of the floorboard mounts..
All went fine today no issues no bottoming out and it handled quit well,the only thing that I didn't think of till tonight was readjusting the head light down,but that's no biggy.The kit was from Road 6 . It was a good test the roads in Philly are real shitty.
Another heads up: my friend lowered his Road King 2" and the little bit of bottoming out he did caused him to wear through the wire cluster on inside top of fender, shorting out his lights.
I used the L.A. Chopper kit, drops you straight down so did not change angle of shocks, got it from a member here and real happy with it....
2013 110th anniversary ultra limited.....
