Oil Leak
Old Nov 5, 2012 | 09:30 AM
Wicked Roadshow's Avatar
Wicked Roadshow
5th Gear
Angry Oil Leak
I'm having an issue with an oil leak from the manifold where the oil filter screws in to the oil cooler on my 07 Ultra Classic. It only appears to be an issue after I've run the bike. The hoses from the manifold have a small amount of oil dripping down off of them. I was asking a parts representative at a local Harley dealership about the issue and he said that they're two gaskets that have been known to be primary issues with leaks (Part# 63066-07 & 63084-07). Has anyone else experienced this issue. The prior oil change was done prior to me purchasing the bike, so is it possible that they just over filled the oil tank and the pressure forces it out the hose connection at the manifold? The oil level on the dipstick does appear to be a little higher than is recommended in manual for a cold engine.
Wicked Roadshow
07 Electra Glide Ultra Classic
Old Nov 5, 2012 | 10:24 AM
Ribitt's Avatar
Ribitt
If the oil filter was installed too tight when you take it off you inadvertently loosen the cooler addapter, so now you will need to remove filter again, take oil cooler adapter off replace that gasket use red lock tite and reinstall adapter and put filter back on only a little tighter than hand tight.
Flying Horse
Aug 14, 2016 12:37 PM
rodney123456
Jan 13, 2013 12:31 PM
alleycat452
Screamin Eagle CVO Models
Mar 29, 2012 09:00 PM
08whitey
Oil Archive (no new posts)
May 14, 2007 06:14 PM
ray
Oct 16, 2005 06:49 PM
