Fender Slam
Old Nov 10, 2012 | 04:13 AM
11FLHR's Avatar
11FLHR
Default Fender Slam
I`ve decided to drop & level the fender on my 11 RK. The most appealing kit I`ve seen is from TWR Baggers Plus. So I sent an email. No response & it`s been 2 weeks or so. Anybody know anything about them or got a phone number ? None listed on their website. Thanx,Don.
Old Nov 10, 2012 | 10:30 AM
RaceFace's Avatar
RaceFace
I had Native Customs weld the brackets into mine and shave the rivets. It came out great!
Here's a before pic:
And after:
Native has a nice kit! Give 'em a shout!!
Old Nov 10, 2012 | 11:24 AM
mkguitar's Avatar
mkguitar
for many of us... visually the fender looks best if the arc of the radius follows the same arc as the disc , wheel & tire.
dropping the stock fender onto the tire can give a "squashed look"- as the eye follows the arc made by 3 things and then sees the fender following a different arc-almost describing a right angle.
for others this makes no difference- it depends what your eye sees.
in the photo above, the forks are also dropped about an inch.
( stock, the bottom of the cowbells is just below the top of the fender, once you know what to look for you can spot a lowering kit)
functionally, you do want a minimum of 3/8" clearance between the tire and the fender- different brands of tire of the same size rating may be slightly different in height and width.
for some riders, the fatboy fender works well ( check the rear ducktail for clearance on the oil cooler or crash bar) or the H-D street stalker fender. both of these use adapter blocks for the mounts.
Mike
Old Nov 10, 2012 | 05:52 PM
roadhog96's Avatar
roadhog96
To each their own, my eyes say it looks stupid but then again, my eyes aren't what they use to be.
Old Nov 10, 2012 | 06:56 PM
skratch's Avatar
skratch
Originally Posted by mkguitar
for some riders, the fatboy fender works well ( check the rear ducktail for clearance on the oil cooler or crash bar) or the H-D street stalker fender. both of these use adapter blocks for the mount.
i was thinking about the street stalker fender, until i found out it was plastic. there aint no way i'm putting a plastic fender on my bike! theres already enough with the trim on the rear fender.
Old Nov 10, 2012 | 07:08 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Maybe this will help..........
https://www.hdforums.com/forum/touri...y-picture.html
Old Nov 10, 2012 | 10:26 PM
11FLHR's Avatar
11FLHR
Default Fender Slam
Thanx for the replies. It is absolutely a visual thing. I think the fender tips "up" too much in the front as well as sitting too high. The TWR kit has that "jig" for drilling the rivets. It is a major reason I`d like to use their kit. But no response from them is not getting me too thrilled to spend $$ with them. Maybe they are busy.or having IT trouble. We`ll see. Don.
Old Nov 10, 2012 | 10:45 PM
131tman's Avatar
131tman
Originally Posted by skratch
Thought about a STREET STALKER fender...ain't no way I'll put a plastic fender on my bike!
Sure you're okay with plastic fairing, sidecovers, bags?
140X18 STREET STALKER - dent proof, awesome fit/finish + way more solid than a tin stocker
Old Nov 11, 2012 | 12:17 AM
drukanfu's Avatar
drukanfu
I personally really like the look of the "slammed" front fender. Hell !..... I even like some of the current rock-n-roll !
Guess I'm just a crazy ole bastard ?
But I don't care.
Old Nov 11, 2012 | 12:32 AM
hockey8787's Avatar
hockey8787
But I don't care.
Me too!!!
