Come to Arizona during the summer when the temp outside is 115 or 120 and that florida heat will feel like winter
Originally Posted by geezer glide 56
Have you ever dealt with the humidity in the deep south?
I've done both and could do without either LOL. Give me mid-nineties with low to moderate humidity and I'm happy.
At least the bike doesn't know what the humidity is, it only knows temperature.
This past summer's trip in early July was the most uncomfortable I've ever done. Miles and miles through the south and midwest with temperatures near and above 100 with equally high humidity. I've done days in the desert at 115 that while hot, were not as uncomfortable as those.
Seems a little low but my question would be why 10-50 in Florida? I would try 20-50 to see if it helps a little. I run 20-50 Mobil 1 V twin synthetic and my hot oil pressure is a little higher like 2black1's.
Mine was also very low at idle, almost 0 on the gauge and noisy when very hot out, I put a stiffer spring in my oil by pass and now have 8 to 10 psi at idle and 36 psi over 2,000 rpm, engine is also much quieter.
I have visited the South West and South East in summer, I will take 110 in the South West over 90 in the South East any day, that South East humidity is a killer.....
I have owned 4 Harleys,only 2 with an oil guage and both of them did as you described. My '03 twin cam has the low pressure system and the early cam chanin adjusters, my '12 has the newer high volume system. Both drop to just above "0" per the fairing guage when hot at an idle and bothe raise to 30 plus or minus when moving. I wouldassume that you will see a low oil pressure light if it drops too low and if no light, the lifters will let you know when they start clacking and your performance drops off with no valve lift.
My oil pressure is up to almost 32 psi and when the bike gets hot it drops considerably. Just barley off zero at idle and maybe halfway between 32 and zero cruising. Running 10w 50W Vavoline V-Twin Syn oil.
Thanks
After making 653 Posts, I'm amazed you don't already know the answer to that question
I may have to try that stuff next riding season but I don't believe the heavier oil has anything to do with the oil pressure.
I installed the Baisley #15 spring and seat and at speed the gauge reads in the area of 50 and at idle in the area of 15-18.
Everytime I read a post like this I cringe. That stronger spring makes the system more restrictive. You are not pumping more oil,you've increased the restriction. Seriously bad idea.
Harleys oil system is high volume low pressure. That spring makes it high pressure low volume.
Absurd. The oil is still a 50 grade at operating temp. The first number is the viscosity in winter(think sub 0 temps). In fact a 10w-50 will flow faster at start up. There is no operational difference between a 10w-50 and a 20w-50 once at operating temp. The 20w-50 is thicker when cold.
Op. In Florida a straight grade is ideal. A straight grade will not shear(thin) over time
My 99 Ultra runs similar to yours. Had a HD mechanic tell me that is normal. Only need to worry about it if the red oil light comes on after it's been up and running.
Not according to some MC performance engine builders. Contact these guys http://baisley.com/oil_spring_product.htm
and tell them your take on the spring and get back to us with the outcome.
Are you sure about that? I'm not intimately familiar with HDs oiling system so I can't say with absolute certainty, but every other oiling system I've seen has a pressure relief valve for one purpose - to limit pressure. Without a pressure relief valve the oil pressure gauge would look like a tachometer. The higher the RPM, the higher the pressure. The pressure has to be limited to prevent leakage and rupturing of componenets such as the oil filter.
As far as I know the pressure relief setting (the spring in this case) has nothing to do with making the oil system more restrictive. It simply allows oil to by-pass the system at a pre-determined pressure. The only way to add restriction to the oil system is by orificing or otherwise restricting an oil galley. Simply changing the pressure relief setting will not do this.
