Struggling ABS
Old Nov 11, 2012 | 07:36 PM
Rickl's Avatar
Rickl
I'd suggest test driving a different streetglide just for a comparison. ABS modulates the pressure of the brake fluid to the caliper based on inputs from a speed sensor. If during "normal" braking you feel the pulsating of the brakes (typically felt through the lever or pedal, a completely different feel then rotors being out of parallelism (warped)) then I would say your waiting too long to brake. I notice on mine a momentary loss of brake if I downshift and apply the brakes at the same time. Nothing I can't live with, just different, especially compared to my wing with ABS and a linked brake system.
Old Nov 11, 2012 | 07:55 PM
sdoomaha's Avatar
sdoomaha
Default Abs
+1 Rikl
When I downshift and hit the rear brakes, or go over a bump or a "rise" in the road and hit the rear brakes I also get the momentary loss of braking...and no the brakes are not locking up. Not sure mine are working correctly...but will have them checked when in this winter for cams...
Steve O!
Old Nov 11, 2012 | 08:02 PM
AlaskaAviator's Avatar
AlaskaAviator
You guys that think your ABS isn't working right just do what Glide said and pull the fuse. I think its a mental problem.
Old Nov 11, 2012 | 08:05 PM
smithbrl's Avatar
smithbrl
Originally Posted by sdoomaha
+1 Rikl
Steve O!
Mine's an 09 and I got the ECM flashed with the upgraded ABS. The front works fine now but the rear still sucks. Kicks in way too soon, in my opinion.
I've wondered if I got some quality rear shocks that hold the tire on the road better, would this solve the problem or at least make it better?
Old Nov 11, 2012 | 08:06 PM
av ultra's Avatar
av ultra
It took me some time to adjust to abs, it's touchy on the back, I found if you use the front a little more then your used to it helps.
Old Nov 11, 2012 | 09:19 PM
tidbit1's Avatar
tidbit1
Originally Posted by Charlie Fogg
ABS will not activate during regular braking to a stop so I would think your problem has nothing to do with the ABS system.
Agree.
Old Nov 11, 2012 | 09:23 PM
Rickl's Avatar
Rickl
I think you missed what I stated. I have no problems braking. It's just that occasional "slip". I am well versed with ABS and have no problems using them. In fact that is why I moved to the streetglide, to get ABS. I also stated that I know my wing has a better ABS system as it is a linked system.
Old Nov 12, 2012 | 05:11 AM
skratch's Avatar
skratch
not necessarily better, just different. some people may prefer a linked system, while others prefer not. me, i prefer not.
Old Nov 12, 2012 | 05:20 AM
VTGlideRider's Avatar
VTGlideRider
I've had my '12 UC since last December. The ABS has gone off once in all that time. I've noticed no difference between these brakes and the brakes on my '10 Classic. As others have said here, during normal braking the ABS should be a non-event.
Honestly this does not sound like an ABS issue...another issue with the brakes possibly, but not ABS.
Old Nov 12, 2012 | 07:39 AM
grbrown's Avatar
grbrown
Unhappy
ABS is an integral part of the braking system, not something that sits on the sidelines waiting for it's chance to work. It is feasible that it's very presence is affecting the way the brakes work while riding, even though the brakes are being used gently. Certainly the only ABS bike I have owned had unsatisfactory feel which I consider compromised their functioning.
Removing the ABS fuse, to electrically isolate it, is worth trying, but I suspect it won't have any affect, nor identify if the rotors are defective. What is needed is a competent ABS expert!
