my first dyno pull
Old Nov 12, 2012 | 09:53 AM
NVS's Avatar
NVS
if you look at the data on right hp and tq are the same @ 5250 tq is nice and flat till about 4000 so if your not a high rev rider should be ok
Old Nov 12, 2012 | 10:50 AM
bigfish_Oh's Avatar
bigfish_Oh
Originally Posted by rg567
Looks to me like the chart "error" is on the scaling. Tq is on a 0-90ish scale, HP is on a 0-70. I bet they'd match up at 5252 if they were scaled the same. HP does look low though. My stage 1 88 makes less torque but more hp than yours. Your power seems to be falling off early like she needs more air...
that makes sense the chart should intersect where the numbers say, definite error. I am going to the Burst collection air cleaner now. I was expecting a little more hp. It is a totally different bike than stock
thanks guys
Old Nov 12, 2012 | 12:13 PM
djl's Avatar
djl
Not that bad for a Stage I with true duals, a crappy air filter, EPA cams and an auto tune. Strap on a Dragula 2:1 or V&H Propipe, SE air filter and get the engine tuned on a dyno; she will wake up. Of course, a set of Andrews 48 cams will make a huge difference, even if you keep the TDs.
Old Nov 12, 2012 | 12:46 PM
carpetride's Avatar
carpetride
thanks guys
There is no error. The hp and torque scales are different on the graph. The curves reflect the chart on the right. You can see how the stock cams fall off quickly. That makes for a lower HP number. Like already said, A good cam will help hold more torque in the higher RPM range and thus increase the HP number.
slammed05fatty
Jun 27, 2014 10:05 AM
badjustbad
Sep 17, 2012 08:25 AM
Cycleman6
Jan 13, 2008 06:41 PM
AggieFan
Mar 16, 2007 06:09 PM
Steele
Jul 8, 2006 04:27 PM
