clutch
Old Nov 13, 2012 | 01:34 AM
TrackMaster's Avatar
TrackMaster
Stage I
Default clutch
Need help.....I press the clutch n as soon as I put it into gear my 06 ultra classic starts moving without even releasing the clutch. I tried adjusting clutch cable. Anyone had same problem? Suggestion......
Old Nov 13, 2012 | 03:22 AM
chriscalabro's Avatar
chriscalabro
when you adjusted your clutch did you do it when it was cold? Did you back off the cable adjuster before making the adjustment? It is possible that your clutch plates are warped. If so just replace the plates and disks, readjust and that should do it.
Old Nov 13, 2012 | 05:25 AM
davidsdad's Avatar
davidsdad
Need to adjust your clutch not just the cable. Make sure you adjust the clutch with the bike being cool.
Old Nov 13, 2012 | 01:57 PM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
Did you follow the procedure in the service manual?
higbee76
Jul 23, 2017 02:55 PM
2013superglideseattle
Oct 4, 2015 09:47 AM
rick775472
Jul 5, 2015 09:08 PM
danny54
Oct 21, 2012 02:24 PM
Beachman
Feb 21, 2011 12:33 PM
