Light Conversion kit installation question
Old Nov 17, 2012 | 01:00 AM
myred55's Avatar
myred55
Default Light Conversion kit installation question
Couple months ago I purchased and installed the Auxiliary Break/Run/Turn Signal Conversion Kit part # 69461-06B. It was a simple installion, just unplug the rear fender lighting connector and plug in the new tail light/ turn signal module and change out the amber lenes to red lenes.
The other day I purchased the Tour Pak Brake Light / Running Light / Turn Signal Conversion Kit part # 69200042A The kit instruction says to plug the module into the same rear fender lighting connector.
Is it possible to have both conversion parts on the bike? Do I need to purchase an adaptor of some sort to plug both conversion kits?
Any help would be greatly apperciated.
Old Nov 17, 2012 | 05:37 AM
old v twin's Avatar
old v twin
Default RBT Conversion
They work together and no additional parts are necessary.
Have been running both for a couple of years.
Old Nov 17, 2012 | 06:14 AM
smithbrl's Avatar
smithbrl
I've been running both for a couple of years also and I'm happy with both. If I remember correctly, it matters what order you plug the modules into the wiring harness. It's in the instructions.
Old Nov 18, 2012 | 12:43 AM
myred55's Avatar
myred55
Thank you old v twin & smithbri for your responses. I finished hooking it up today and works great!
Old Mar 6, 2013 | 01:14 PM
JTomo170's Avatar
JTomo170
6th Gear
I recently purchased and installed the kit on my 10 Ultra. The left light on the tour pack will not flash with the left turn signal. Any ideas as to why this may be happening? I double checked everything and it's installed correctly.
Old Mar 9, 2013 | 01:06 AM
smithbrl's Avatar
smithbrl
JTomo
Does the right light flash? Does the left brake light on the tour pack work?
Old Mar 9, 2013 | 04:37 AM
Harleypingman's Avatar
Harleypingman
I suspect that the insertion of the wires into the connector that connects under the seat was not right.
Carl
Old Mar 9, 2013 | 06:51 AM
jeffreydsilver's Avatar
jeffreydsilver
Carl
I installed the tourpak LED light kit and the wire insertion thru me for a looper for a few days. Once you get the wire insertion into the mollet connector correct, it should work fine.
NKy Ultra
Mar 5, 2015 08:21 PM
jeepn
Sep 28, 2013 05:37 PM
steved1977
Jan 27, 2013 04:28 PM
rickoshay45
Apr 21, 2007 08:13 AM
capt42a
Nov 2, 2005 10:49 PM
