Max voltage should read?
Old Nov 18, 2012 | 11:14 AM
RAP's Avatar
RAP
http://www.sparkbright.co.uk/product...monsoon10.html Got one of these coming, going to give it a try.
Old Nov 18, 2012 | 11:40 AM
CRogers1's Avatar
CRogers1
Thanks for the replies....I'll check at battery and see how far off the gauge is.
Old Nov 18, 2012 | 12:35 PM
Chunker's Avatar
Chunker
The 2 reading measured at the battery would be the 12.7 with the engine off and the 14.3-14.7 with the engine running. I have measure mine that way and get those results. Idling low or fast makes little difference. As was stated, the gauge reading can be just about anything. Mine is generally high by a volt or so. if I started getting different reading, I will check at the battery form correct ones.
Old Nov 18, 2012 | 02:24 PM
DPete's Avatar
DPete
10-4 thanks, my riding bud has a RK, no charge indicator at all, we need to check to see if his charging system is OK after a new battery
Old Nov 18, 2012 | 05:28 PM
Tinman265's Avatar
Tinman265
My Limited's gauage reads 14v but my buddies SG reads 16v. He was concerned so we put a meter on both bikes. His is 2v off and mine is dead on. Both bikes are 2011 and had the same voltage at the battery at the same rpm.
Old Nov 18, 2012 | 05:31 PM
Gliden's Avatar
Gliden
I just installed a digital Dakota volt gauge.
When I'm riding typically she's charging at 14.1 at cursing rpm with a lot of stuff on.
Powertrip240
Jun 21, 2015 12:55 PM
1sparky
Electrical/Lighting/Alarm
Jul 22, 2014 07:56 AM
Michael Gamboa
Apr 25, 2014 06:58 AM
flynavy
May 20, 2013 11:44 AM
fabrik8r
Jan 12, 2011 08:34 PM
