Ipod Interface
Old Nov 18, 2012 | 12:09 PM
Cep10SG's Avatar
Cep10SG
Default Ipod Interface
Hello everyone, i just wanted to pass on some possibly useful information. i was doing a search for a way to connect an Ipod without blowing the bank last night and as most of you know, HD sells their Ipod Interface for a pretty penny. I found this company called "on the move technology" and they have an Ipod Interface that goes for 279.00. there's a video on YouTube and pictures online on the installation.
Cep
Old Nov 18, 2012 | 12:14 PM
Gonzy's Avatar
Gonzy
Gonzy
I bought one from Iron Cross Audio, I think they're one of the advertisers here, for $250.00 It works like a charm.
Old Nov 18, 2012 | 12:35 PM
scootinz's Avatar
scootinz
I was just going to post up asking about the Iron Cross set up Gonzy. So that set up does everything the HD set up does? Looks like install is much easier too?
Started reading the other 22 page thread here titled the same at this on (did a search on Ipod Interface) and it looks like the HD set up is a major PITA with inserting wires etc. Is the iron cross literally plug and play? Looks like maybe 2 wires have to be inserted in the connector?
http://www.ironcrossaudio.com/ipod-h...dsonradio.html
http://www.ironcrossaudio.com/INSTALLATION.pdf
Old Nov 18, 2012 | 12:51 PM
bgdv1's Avatar
bgdv1
bought the HDPD plus from OTMT this spring for my SG. im using an older ipod nano and it works great and way less than the HD unit.
Old Nov 18, 2012 | 01:06 PM
1mesaman's Avatar
1mesaman
5th Gear
You guys have it nice, I have to use my head phones. I still like it, wind in my face and loud pipes!
Old Nov 18, 2012 | 03:28 PM
Bushy's Avatar
Bushy
I did the iron cross interface, customer service is unbelievably great and product is solid, I did run two lines from battery to unit direct with a fuse on power , used the spade connection and no hacking into the harness.. did this on my 2012 Limited,, works great!!
Old Nov 18, 2012 | 05:50 PM
skratch's Avatar
skratch
looks like otmt has changed the setup for their controller. you now have to purchase an 'extension' kit if you want to put it in your saddlebag. that raises the price up to $310 from iron cross. i got my hd version at discount for $330, though i did not get the extension to put it in my saddlebag. the stock cable was plenty long enough to keep my ipod in my fairing compartment.
the install for the hd version is not really that bad. sure, it looks intimidating at first, but if you go step by step, it is pretty simple. my first one took about an hour and fifteen minutes. when i did it on my wife's bike, about a half hour.
either way, if you go with otmt or hd, the iPod controller is a great item to have. you can hook up your iphone to it, listen to internet radio, keep your phone charged
Old Nov 18, 2012 | 07:09 PM
hulkster's Avatar
hulkster
Stage II
Default A vote for Iron Cross Audio
I also installed the Iron Cross Audio Interface. Works great and install was a beeeze
Old Nov 18, 2012 | 09:25 PM
Gonzy's Avatar
Gonzy
Gonzy
Yep only 2 wires to connect. I would recommend soldering the wires instead of using the supplied connectors. The first time I used the connectors but the ground was bad so I took the fairing off then soldered the wires like I should have done the first time. The Ipod connector cord that came with my kit was long enough to go into my right side saddleback.
Old Nov 18, 2012 | 10:06 PM
scootinz's Avatar
scootinz
I think I'm going to go the Iron Cross route. Looks like it's a all around better deal. I have 2 cell phones (one for work and one personal) and one is a the Iphone 4. Problem is Its already full and I want to add more music. I like the idea of the deal to the saddle bag, but the more I think about it I think I am just thinking of buying a nano (16GB and my Iphone is only 6.5 GB) and leaving it in the faring. I guess the only advantage with having the set up in the bag would be using internet radio. If I really wanted to do that I could always just plug the Iphone into the face of the deck for that or using it for navigation....
