PCIII install
Old Feb 1, 2007 | 09:45 PM
JeffSG's Avatar
JeffSG
Default RE: PCIII install
Call Jamie...he'll tell ya to do the closed throttle setting. Verrrrry important.
Ride safe,
Old Feb 1, 2007 | 10:29 PM
Hinzy's Avatar
Hinzy
Its very impotant you zero the throttle.The pc must be on the bike the bike must be warmed up and running and you hook your laptop to the pc and zero the throttle.
If you don't your maps are ineffective no matter who you bought it from.
Check out www.powercommander.com and go to the tutorial section.
It explains everything in detail.
hope this helps
Hinzy
Old Feb 1, 2007 | 11:33 PM
98rdking's Avatar
98rdking
What about the fuel accelerator? Is this something we need to adjust or does it come preset from fuelmoto?
Old Feb 1, 2007 | 11:39 PM
capt42a's Avatar
capt42a
Hinzy,
Thanks for the link to the Powercommander site.
capt42a
Old Feb 1, 2007 | 11:49 PM
SteveO's Avatar
SteveO
The PC III you install on your bike must be set on your bike to your bikes throttle settings.
The PC III can not be preset with your bikes "0" throttle setting! All are different by just a fraction, therefore you need to set the "0" throttle yourself on your bike! You really don't need to set the "100" % or full throttle position, but it can be set either with the bike running or with the 9 volt battery connected.
I found it very.... very... very...helpful by reviewing the the tutorial section on the Power Commander web site www.powercommander.com
It will walk you through all your questions.
I found the acc pump doesn't do much except use a lot of gas, and mess up the program. I don't like it, but some swear by it.
SteveO
Old Feb 1, 2007 | 11:59 PM
voodoodrug's Avatar
voodoodrug
Somewhere I read that acc pump actually saves gas(provents a breif choking at cruising speeds)?But this never really amde sense to me.
Old Feb 2, 2007 | 12:48 AM
Custom07RKC's Avatar
Custom07RKC
ORIGINAL: kgjl
It is so easy, even I was able to do it. I am someone who is envious of cavemens abilities.
GEICO...So easy even kgjl can do it
Sorry I couldn't resist
jd_cincy
Dec 31, 2012 02:51 PM
jackinthebox
Apr 18, 2011 09:47 PM
jackinthebox
Feb 25, 2009 05:07 PM
Kbore
Aug 24, 2008 02:01 PM
swipter
Oct 21, 2007 10:49 AM
