HD LED's
Old Dec 4, 2012 | 08:54 PM
  #31
Charlie Fogg's Avatar
Charlie Fogg
Originally Posted by candave650
LED's are almost invisible during the day if you look at them from much of an angle.After having all LED lighting(HD) and having numreous close calls from cars not seeing me when pulling out from a sideroad,I now run stock lighting with PIAA bulb.
LED's are definitely great at night,but if you want better daytime visibility they didn't justify the expense IMO
Ineresting...these last two posts present an opinion/perspective I have not previouly heard but I will look into further before pulling the trigger.
Old Dec 5, 2012 | 03:40 AM
  #32
bklynbob's Avatar
bklynbob
I disagree,the Hd spots throw a nice wide beam. I adjusted them slightly higher than spec,no problem being seen.Did the same for the rear end,i put a light with a convex lense/housing that is super bright (post#18).
Old Dec 5, 2012 | 04:58 AM
  #33
Guzz's Avatar
Guzz
I have not yet done the spots, but have to agree about the TruckLite LED headlamp, in the daytime you can't even tell it is one unless you are at the right angle.
Old Dec 5, 2012 | 09:49 AM
  #34
bowhunter13's Avatar
bowhunter13
3rd Gear
Default Is it a direct fit?
Originally Posted by stupid_rope
discountfleetsupply.com, trucklite headlight and spots, save yourself about $500
I need to upgrade my headlight, but on a budget..
is the Truck-lite 7" from discount fleet supply a direct swap from the OEM lamp?
HD wants over 500 bucks for a light and an hour to put it in.
I have a 11 Street glide,,,looks pretty simple to me.
ANY guidance is greatly appreciated
Old Dec 5, 2012 | 10:53 AM
  #35
ratdoc's Avatar
ratdoc
Yeah, the Truck-lite is a direct replacement and an easy swap. You'll probably have to adjust the beam height, but again, easy to do.
Old Dec 5, 2012 | 06:56 PM
  #36
stupid_rope's Avatar
stupid_rope
super easy. literally plug and play. dont let the adjustment scare you either. PM me if you need some help
Old Dec 6, 2012 | 08:32 AM
  #37
bowhunter13
3rd Gear
Default Thanks!
Thanks for the replys!
FYI 4wheel parts... 180 bucks, not sure if that one will work.. looks like an older style.. 10 LED's instead of the new style 2727OC
Old Dec 6, 2012 | 11:54 AM
  #38
TKDKurt's Avatar
TKDKurt
I am satisfied with my headlights and auxiliary lights, but one of my first mods was swapping out the wimpy taillight and turn signals for HD LED's which are great and greatly increase visibility from the rear. Another member posted this photo (I did the labels). Note how the LED's although further away, are far brighter than the closer standard set up.
Old Dec 6, 2012 | 04:58 PM
  #39
bowhunter13
3rd Gear
Default replacements
Can you just add LED lights to exsisting housing for running/turnsignal lights from and back?
Old Dec 7, 2012 | 01:27 AM
  #40
SoCalMike's Avatar
SoCalMike
Short Answer is Yes. Not sure about HD LED's, but with any other LED you'll need to add a load equalizer for them to work right with the stock electrical system. I used the Custom Dynamics running/turn/brake units along with their load equalizer. I was turned on to a load equalizer by Biketronics that doesn't require a connection to the battery and members have sworn by them for years. If I was going to do it, I'd get the Biketronics plug and play version, but still love the CD units. There's some posts about comparing various units other than HD. I wrote one back in about March of this year with some additional pictures if you want to look it up. Best single safety investment I've done, and gets used every single time I ride.
