Shift shaft seal
Old Dec 2, 2012 | 03:26 PM
jmn1960's Avatar
jmn1960
Question Shift shaft seal
2005 ultra
can the shift shaft seal be changed without removal of the primary??/ if so how,, i think i could pick it out but worried that i wont be able to get it back in,, any tricks?? can it be done/,, i hate leaks ,,just a drop or two here and there but would like to fix it
thanks mike
dawg's Avatar
dawg
Gotta pull the primary. Best to change out all the seals too.
Old Dec 2, 2012 | 03:30 PM
dawg's Avatar
dawg
I also like to use a homemade puller that I made. Pulls 'me off slick
Old Dec 2, 2012 | 04:00 PM
jmn1960's Avatar
jmn1960
that what i was affraid of,, oh well gonna leak for awile,, got a manuel but kinda affraid of getting in there
Old Dec 2, 2012 | 04:04 PM
dawg's Avatar
dawg
Don't be afraid. Not real hard.
Old Dec 2, 2012 | 04:12 PM
Redbeard719's Avatar
Redbeard719
Did the exact same thing when I replaced mine. That old seal won't just fall out and there's no picking it. Just go easy with the drill wheel you punch two holes in the old one for the screws to seat into.
Agreed. Pulling the primary is easy potatoes with a manual and the right parts.
Some good videos on YouTube. Just remember, the Mainshaft nut in the clutch basket is a left-handed thread. Right to loosen, left to tighten.
Old Dec 2, 2012 | 04:16 PM
drukanfu's Avatar
drukanfu
Shift Shaft Seal.....try and say that fast 3X. Without making a Chinese face !
Old Dec 2, 2012 | 04:52 PM
jmn1960's Avatar
jmn1960
do i have to remove the clutch assm.?? any special tools needed?
Old Dec 2, 2012 | 05:36 PM
Streetrunner's Avatar
Streetrunner
I just had that seal and all associated gaskets replaced on my '06 SG. The primary has to be pulled. I had the dealer do it and it cost me about $450.
Old Dec 2, 2012 | 05:42 PM
dawg's Avatar
dawg
Yes you need to pull the clutch and compensator. You will need a locking bar which can be a small piece of flat stock. You will need a large socket purchased separately unless you already have a 1 3/16 socket. The compensator takes 1 1/2 socket. A breaker bar is nice, but a piece of pipe can be put over the ratchet and get the job done. To remove the inner primary bearing you can use a socket and a jack underneath a car as leverage if you don't have a press.
