looking for help - rough running
Old Dec 4, 2012 | 03:34 PM
V2Evo96's Avatar
V2Evo96
bellgnte, the codes that you saw certainly affected your system. I have only seen the clock reset when 12v power was lost for whatever reason-- blown fuse, pulled fuse or a disconnected battery.
My glide went into limp mode with codes and nothing happened to the clock but not saying a certain combination of codes couldn't do that.
Combustion pressure cannot close that plug gap. It has to be either something in the cylinder which would likely have done a lot more damage that just close that gap, or the gap was deliberately closed or plug dropped on the electrode.
Do you have compression in that cylinder? Is the bike runing OK now after a plug change?
Old Dec 4, 2012 | 04:50 PM
VTL nut's Avatar
VTL nut
As far as the clock reset, I see in the 1st post(s) it was mentioned about checking grounds, pulling fuse(s). If by checking grounds you removed them, and retightened connections, along with fuse removal, one of these caused the clock reset.
Old Dec 4, 2012 | 06:28 PM
Mark_H's Avatar
Mark_H
Did you **** off anyone recently that would pull a plug and do this?
shane_moto33
Jun 13, 2015 03:25 PM
Dirknar
Jul 8, 2011 02:36 PM
prostreetdon
Jun 8, 2010 11:59 AM
firegrizz7
Apr 20, 2009 07:27 AM
vheflin
Sep 10, 2006 12:05 PM
