From: Western Illinois, land of bad roads, and corrupt politicians
Originally Posted by Chopperbob
I have the push button fob security works with it
Fine but the guy I bought didn't even know it had
Security I found the fob in the tour pak replaced the
Battery in the fob and it works the bike. I just don't
The pin if I lost the fob. I want to find it without doing to
The deler. I have no owners manual for it either
The pin is probably all 1s since the previous owner didn't know about it.
If you have button fob , turn switch on, off, on, off, on , push left turn two times then push fob button two times all within two seconds, your code will flash in odometer, then you can change code from there.
Chopperbob, you can go to the HD website, look for the Owners Manuals page, enter the VIN for your bike, and read the owners manual for your specific scoot. It should tell you what you need to know. Hope this helps.
