The Easy Way to Center a Tour Pak Rack
Old Dec 8, 2012 | 12:51 AM
HalfFast's Avatar
HalfFast
Default The Easy Way to Center a Tour Pak Rack
1- Cut the heads off of four ź”x1” bolts and one with a cut off wheel or hacksaw.
2- Use a grinder to center sharpen one end of each bolt.
3-Place your tour pack rack on top of your tour pack and center it best you can.
4-Use a Sharpie and place a mark beside each of the rack feet.
5-Place a piece of masking tape over each mark.
6-Screw the unsharpened end of each bolt into the rack feet.
7-Place the rack on the tour pack and center it.
8-Press down on the tour pack so that the bolt points pierce the masking tape.
9-Remove the rack and use an awl or center punch to make a starting point for drilling.
(Press and spin the awl or center punch into the plastic. DO NOT HIT THE PUNCH WITH A HAMMER)
10- Leave the tape in place and use a 1/8” bit and drill each of the four holes.
11-Set the tour pack rack back on tour pack and check the location of each hole.
12-Use a ź” bit to drill your final holes.
13-Remove the drill debris and tape.
14-Use rubbing alcohol to remove the Sharpie marks.
15-Place the rack on the tour pack and start all four bolts then tighten each bolt.
The entire process takes about an hour.
One of my bolts is 5/16" because wire is threaded through the center of of the bolt in that leg.
Old Dec 8, 2012 | 05:19 AM
riteway's Avatar
riteway
Nothing "HalfFast" about that installation description.Thanks for the pictorial...
Kudo's to you...
Old Dec 8, 2012 | 06:53 AM
jeffreydsilver's Avatar
jeffreydsilver
Default That'll Work!
Of course you could always place masking tape over the general areas that the rack will sit, center it with a ruler, make sure it looks right and then trace the 4 posts onto the tape. After that you center drill (center punching might crack the plastic) and bolt it into place. Undoubtedly, your way would probably be more accurate? In either case, your install looks great!
When it comes to life in general I try to live by the acronym KISS!
Old Dec 8, 2012 | 07:39 AM
1flhtk4me's Avatar
1flhtk4me
Yep,transfer punches work good.
I think it's still a good idea to measure the hole to hole locations on the rack then layout the hole positions on some painters tape.
Old Dec 8, 2012 | 09:58 AM
hog95023's Avatar
hog95023
I think it's still a good idea to measure the hole to locations on the rack then layout the hole positions on some painters tape.
I'm glad you feel that way buddy, cause HD ordered me a new tour pack yesterday. Guess I have to do the hinges and rack again lol
Old Dec 8, 2012 | 10:13 AM
mike lhc's Avatar
mike lhc
Ever try lip stick? Smear it on the part and place it on the item to be drilled.
Old Dec 8, 2012 | 10:22 AM
mnclassic's Avatar
mnclassic
Or ..............................
Let the dealer do it and it's their problem if they mess it up! LOL
Old Dec 8, 2012 | 10:43 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
This was discussed in a previous thread, and someone used a measuring tape (made of tissue) to center the rack.
Old Dec 8, 2012 | 10:45 AM
doghair's Avatar
doghair
Good write up. When I did mine I covered the post areas with masking tape and used more tape to make a tie down as-it-were on each corner of the rack. After positioning and measuring (for what seemed like hours) I marked the tape around the posts and went at it with the drill. I made the holes just a hair bigger than needed so there would be no stress on the lid.
Old Dec 8, 2012 | 12:53 PM
HalfFast's Avatar
HalfFast
This aint my first trip to town.
When I mounted the rack on the tour pak on my last bike, I tried HD instructions which got me in the ball park of the final location but it wasn't centered. Next, I tried the lipstick method but I used Dykem lay out fluid. I had 4 big blue spots to guess where the center of each foot was so I wiped all of that off and tried marking around the feet and finding the center of each hole. Then I had to over size each hole to make it work.
That is when I decided if ever mounted another one, I would do it the way I described in the beginning of this post. I traded bikes and whalah!
What took me about 4 hours before took me less than an hour to do last night.
Just to think... They say that when you get older, it takes all night to do what you used to do all night.
