Tour Pack Lock
Old Dec 9, 2012 | 04:23 PM
larsfum's Avatar
larsfum
+1 on graphite lubricant.
http://www.walmart.com/ip/Graphite-Lubricant/19512261
Old Dec 9, 2012 | 05:34 PM
ElvisNOklahoma's Avatar
ElvisNOklahoma
Default Fixed
Well decided to try something and it worked. Since the lock was stuck halfway between locked and unlocked and I couldnt get the key in I took an old key and ground off the little part that goes in the slot. It went right in and I was able to turn it. Workes like a charm now. I tried the key on my friends bike to make sure it wouldnt open his and it didnt. For now on I will carry this as an extra in case it happens again. I appreciate all the replies. I do keep all locks lubed as many suggested so I knew that wasnt the problem. It just seems to rotate to half way between locked and unlocked on its own as I am riding.
Old Dec 10, 2012 | 12:25 PM
Guitar4Him's Avatar
Guitar4Him
It could be because of vibration. I've heard that some H-D's vibrate.
Old Dec 10, 2012 | 01:41 PM
DXHD $100's Avatar
DXHD $100
Take your extra Key and file the notch off the outside then unlock it. Same thing happen to my buddy's saddlebag Locksmith told me this happen because when barrel locks get too much wear on them.
Old Dec 10, 2012 | 01:50 PM
CndUltra95's Avatar
CndUltra95
Originally Posted by 1flhtk4me
I think you would have to disasemble the lock to get the grease in.
not if he uses an aerosol type grease.
Have you checked to see if the screw that holds the lock together is tight?
You need to have the lid open and look close..well not that close if you dont need glasses.
Rob
Old Dec 10, 2012 | 02:00 PM
HalfFast's Avatar
HalfFast
The same thing happened on my buddy's bike while we were in Helen, GA this year. Apparently, it is not that unusual of an occurrence.
Old Dec 10, 2012 | 02:27 PM
DXHD $100's Avatar
DXHD $100
When it happen on my buddy 's 2009 the notch on the key was worn enought to slip out leaving the lock in between stops. So when took the notch off the key he was able to reinsert the key where the lock have stop, it is still working today.
Hades02
May 9, 2016 06:03 PM
remike
General Topics/Tech Tips
Sep 27, 2012 09:09 AM
mike79
Dec 1, 2011 05:15 PM
flyguy9631
Nov 16, 2010 11:51 PM
THABULL
Jan 11, 2007 12:12 AM
