Tranny Issue
Old Dec 12, 2012 | 02:02 PM
SkipCarey's Avatar
SkipCarey
Im gonna say this.....if you been ridin in the rain a lot it doesnt hurt to pull the shifter linkage off and grease the front bushing at the shifter , i had one do it to me it quit shiftin to second, either way what do you go to lose but some grease and twenty minutes
Old Dec 12, 2012 | 03:53 PM
0ldhippie's Avatar
0ldhippie
My 2000 RK started jumping in and out of 3rd. Very weird, almost like the compensator was overrunning? Tried adjusting with no luck. Pulled it apart and everything had alot of wear (tough life behind 95") so put revtec 6 speed gear set in. Really like the ratios in it compared to my '09.
Old Dec 13, 2012 | 06:42 AM
Scrmnvtwins's Avatar
Scrmnvtwins
Forgot to mention shifter forks, straight is critical- Stock forks in my '89 used powdered metal, compaction press and sintered technology. After many years of my abuse to the shifter they became bent. I purchased new form the dealership and the repalcements were forged iron.
I solved my slide in and out problem with new forks, replaced the drum detent and just for good measure added a Sputhe Pos-Shift. If you havent seen 1 it simple is a mechanism on the end of the shift drum that will only allow 1 gear change at a time and guarantees the detent is engaged in the drum.
I am in to full throttle shifting and stomping the crap out of the heel shifter, never missed a gear after installing the Sputhe Posi Shift.
17-0111-VT Sputhe 5-Speed Posi-Shift for 1989-up Harley Big Twin
rigger4343
Dec 28, 2016 04:21 PM
Jfish84
Aug 9, 2010 10:33 AM
38knuckle
Shovelhead
22
Jun 13, 2008 01:40 AM
Clarkit
Apr 21, 2008 10:12 AM
Jmehaff
Jul 29, 2007 12:07 PM
