If your indy doesn't know that the left grip isn't glued on for the newer bikes, including your 2010, you might try finding another indy.
If you have some mechanical abilities, installing new bars isn't very difficult. Time consuming, maybe, but not difficult. Especially if you are keeping your cables.
From: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
thinking about doing mine on my road king, dont want to change cables but whatr bars and anyone got a link to a video or something to help assist another apprehensive oil change and slip-ons olny type mechanic.
I went + 4" on the clutch cable and it took me a whole weekend to put the sweepers on. Okay I did take my time and I fitted new grips I wired external wiring, internal may take even longer.
$140 labour is a steal!!!! over here they want $1000 in labour to change a set of bars on a SG.
Just purchased a set of Khromewerks 2+2 (300516) for my 2010 RKC. I've been thinking about following the outstanding pictorial instructions posted by DrJay, but would have to buy the torque wrenches to complete the job.
I called a local indy that quoted a total price of $140.00 (two hours labor) provided no cable changes are required, which I don't think are needed. He also recommended I have a pair of new grips ready incase he has trouble removing the left grip. I'm thinking $140 is worth the time and frustration that I would put myself through. Any thoughts before I pull the trigger?
$140 doesn't sound like much because it's an easy job. I'm guessing you are not doing any internal wiring either. No cable change and no internal wiring is a cake job. I could do it in an hour.
Timmy B, here is the pictorial I was going to follow, its the first really good "how to" I've seen on changing bars:
If you have any apprehension about doing it yourself, you need to let someone else do it. Start out doing something easy like changing oil or something and work your way up to harder stuff. Just my 2 cents. $140 is very resonable for this job.
Mike
I've been seriously thinking about the suggestions, and I really want to dig into this bike myself. I think I have the capability, but was just lacking the confidence until I read some of the posts and Dr Jay's how to thread. I'm going to run buy Harbor Freight tomorrow and look at their torque wrenches (I agree that I might need them on other projects). Then I need to pick up a maintenance manual. I still have one for '04 touring models, but that was pre-TBW.
I was not aware about the left grip not being glued, but its good to know. Using the current grips will save some money.
I think it is a pretty simple job on a Road King especially if you leave wiring external, and don't have to extend wires, or replace brake & clutch lines. A dealer quoted me $300 to $350 labor to change the bars. I didn't laugh or snicker until I got outside. It's a lot simpler when you don't have to remove the faring.
