piston-valve clearance
Old Dec 12, 2012 | 08:31 AM
heavyd460's Avatar
heavyd460
Default piston-valve clearance
Hey Guys,
Quick question:
2011 Road Glide, 103", 54H Andrews cams, 0.030 H/G, Heads ported polished and taken down 0.015. Stock valve sizes, stock pistons
I don't have my heads back yet, so I'm just asking for simular build expieriance.
What can I expect for piston valve clearance?
I have read a ton of info here (all excellent), but have seen no input from any one with this set up. I will clay them any way, but I don't think I will have any issues, as my pistons sit down in the cylinders close to 0.080 at TDC.
Any and all welcome, thanks
Old Dec 12, 2012 | 11:51 AM
0ldhippie's Avatar
0ldhippie
You should be fine. I do think HC pistons would be better than shaving the heads + gaskets.
Old Dec 12, 2012 | 12:09 PM
djl's Avatar
djl
Originally Posted by heavyd460
Hey Guys,
Quick question:
2011 Road Glide, 103", 54H Andrews cams, 0.030 H/G, Heads ported polished and taken down 0.015. Stock valve sizes, stock pistons.
I can't tell you what to expect exactly but clearance should be in excess of .100"; the 54 has a low TDC lift. I am currently running TMan's 600SM in an all bore 107", heads shaved .010" with a .030" head gasket with valve to piston clearance on the intake at .090"; more on the exhaust. The 600SM has a TDC lift about .030" more than the 54.
BTW, I doubt that your pistons are down in the cylinder .080"; maybe .008"??
Old Dec 12, 2012 | 12:46 PM
heavyd460's Avatar
heavyd460
hahahahaha, your right, 0.008".......dyslexia rears it's ugly head again
Thanks for the guidance guys!
traveler
Exhaust System Topics
Mar 25, 2020 10:04 PM
GibsonSG
Engine Mechanical Topics
19
Feb 27, 2016 10:00 AM
txphatboy
20
Apr 16, 2013 07:47 AM
Joker65
Jan 30, 2012 06:51 PM
softail99custom
EVO
Jan 21, 2010 08:45 AM
