Extended reach handlebars
Old Dec 13, 2012 | 08:30 PM
jrat69's Avatar
jrat69
Default Extended reach handlebars
Any one tried the extended reach bars on a Road King? I was at a dealer today and ask about them. They didn't have any in stock, bit could order them $90 (full list) but said I would have to replace upper & lower brake lines with braided, wiring extensions braided clutch cable (which I might not need) and a new tbw, for a total of a little over $1000. I believe that those bars can be put on withour any extended cables or lines from what others have said. If anyone has tried then what are your thoughts.
Old Dec 14, 2012 | 07:40 AM
mrwatson75's Avatar
mrwatson75
Are the measurements posted? I put wo550s on with stock cables ...just had to extend switch wiring..not sure how those bars compare to the 550s
Old Dec 14, 2012 | 08:15 AM
taconite's Avatar
taconite
I just took off the extend reach bars I had on. Everything was stock other than the heated grip wires. I hated the bars, but I am 6'3". they were an ordering mistake when I had the bike repaired after a crash. I have them in perfect condition for $45 if you want them.
Old Dec 14, 2012 | 08:26 AM
ontwowheels77's Avatar
ontwowheels77
I just installed the Extended Reach and love them. Absolutley no replacement of any eletrical, brake, or clutch cables required. The Extended Reach are similiar in specs to the Heritage style but with the wider base, it looks closer to the stock handlebar than the more narrow base of the heritage style. You can also run the electrics internal if you'd like. Great set of bars!
Old Dec 14, 2012 | 09:03 AM
jcannady's Avatar
jcannady
PM sent
MMLee
2018+ Softail Models
Jul 24, 2019 01:49 PM
Buckinfitch
Dec 16, 2011 06:47 PM
atrox88
Apr 24, 2008 03:03 PM
kemp427
Mar 13, 2007 01:13 AM
Inforit
Sep 17, 2005 04:01 PM
