Handle bar bushings solid mount ?
Old Dec 18, 2012 | 08:44 PM
3itodd's Avatar
3itodd
Default Handle bar bushings solid mount ?
I'm putting done apes on my street glide and I was thinking about using solid handle bar bushings .. Is there much more vibration with them than stock rubber bushings ? Thanks !
3itodd's Avatar
3itodd
Some*
Old Dec 18, 2012 | 09:05 PM
kennygsuperglide's Avatar
kennygsuperglide
There is a little more vibration, but it takes all the "slop" out of the bars. The pro's outweigh the cons, imo. I put solid mounts on mine. Even with the nylon bushings my bars would still move a little. So, I had a freind make me a set of alluminum ones. Mine are totally rigid. Can't see out of my mirrors at an idle but my bars don't move.
Old Dec 19, 2012 | 01:11 AM
kojak's Avatar
kojak
Try the polyurethane bushings.
Old Dec 19, 2012 | 06:34 AM
LarryLives's Avatar
LarryLives
Yup, what Kojak said, and tighten the hell outta them.
Bars will be plenty stiff and u can still see in mirrors and hands wont get sleepy...
Old Dec 19, 2012 | 07:25 AM
3itodd's Avatar
3itodd
Do the solid ones vibrate alot while riding?
Old Dec 19, 2012 | 12:32 PM
glcash's Avatar
glcash
I have the Polly bushings on my 14s. My bars still move a little bit when il you pull on them. It's too much work to replace them with something else so...... I'm fine with it.
Old Dec 19, 2012 | 07:39 PM
kennygsuperglide
No, not that i've noticed, but at a stop light my bars dance so much my levers rattle. My Superglide shakes alot at idle, (dealer says, "it's a Superglide, It's supposed to shake."), But with the rigid bushings and 18" apes, my mirrors are useless at a stop. They smooth out right off idle. No numbing of hands or anything. I had the Neophrene, or nylon or whatever you call them,(hard plastic),but my bars still moved. With the aluminun they are solid as a rock.
Old Sep 21, 2025 | 02:34 PM
Lfish61's Avatar
Lfish61
Stage I
Default SLEEPY ?
Son at the speeds I roll at, there's no sleepy, to much adrenaline in the system!. 64 yo rider, 07 Stree Glide, SE Heavy Breather A/I, dual TAB BAM Stick slip on's, PV3/with Autotune Pro, Wood 222-6 cams, 107 big bore with high output heads on the way PEACE
Old Sep 21, 2025 | 04:18 PM
AMP'd's Avatar
AMP'd
Get the solids. You’ll barely notice the vibration at first, and not at all before you know it.
