2012 street glide 103 performance mods
Old Dec 22, 2012 | 08:52 PM
06redneck's Avatar
06redneck
Default 2012 street glide 103 performance mods
Hey guys,
Im about to tear into the bike and wanted to see what you guys think on the mods while im taking stuff off to powder coat. I ordered a thundermax tuner, ordered two sets of pipes for an 09 touring (18mm bungs for 02 sensors). i have a PM fast air intake. My question is, do any of you have experience with 255 cams for the 103 on a touring bike, my buddy has a set laying around. Just wondering if i should throw them in there while i have the cam cover off. I have D&D fat cat 2n1 and a thunder header 2 n 1. Which pipes put out more horse power? thanks, look forward to picking yalls brains.
Old Dec 22, 2012 | 08:55 PM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
What are the stock cams in a 103?
Old Dec 22, 2012 | 08:58 PM
Sagido's Avatar
Sagido
I just picked up a set of 255s, but have read good reviews. With an open intake/exhaust very nice gains arr expected.
Old Dec 22, 2012 | 09:12 PM
06redneck's Avatar
06redneck
no clue
Old Dec 22, 2012 | 09:13 PM
06redneck's Avatar
06redneck
are adjustable pushrods needed? im taking off the rocker boxes to powder coat them too.
Old Dec 22, 2012 | 10:26 PM
Tinman265's Avatar
Tinman265
No you do not need adjustable push rods going thru the top like that.
As for the stock cams they are the same cams that have been used since the 96" motor has come out. Since you are doing a tuner I say put the cams in and change the inner cam bearings while you are in there too. I have the same cams waiting to go in myself....... Good cams for low end torque. Ask you tuner, if you are going to use one, which pipes are better, or should say, he has an easier time tuning.
Old Dec 23, 2012 | 08:35 AM
Guzz's Avatar
Guzz
If you already have them, and it is going to be apart... go for it. The HD site, and 1000's of threads here leave no doubt that it is an improvement over stock. I myself put one in last year and am very satisfied with the boost in performance.
Old Dec 23, 2012 | 11:14 AM
twistedc's Avatar
twistedc
4th Gear
Had a set in my 08 255s sert V&H true dules air intake got me 100hp n 100 Ftlbtq kicked in around 2100 held 45+ good all day runner around 100mph strong off the line faded on top end above 100 ride two up fully loaded / with my 2012 flhx went a little more rad woods TW888 cams port and polished heads polished intake roller lifters cam bearing upgrade oil pump up grade seprt stock header with cat removed 100hp 111ftlb tq and now have droped gearing to pull better should bump Tq another 7% match your cam to how you drive most of the time you won't be disapointed that way.
Old Dec 23, 2012 | 01:14 PM
0ldhippie's Avatar
0ldhippie
I'm not a fan of the 255s but if they are free/very cheap they are an easy swap if ya got it apart anyway and better than the stock cams for sure.
ryansg
Feb 2, 2022 12:26 PM
Blue Tick
2014-2024 Touring Models
13
May 19, 2018 04:40 PM
jfsimi
Exhaust System Topics
Jan 27, 2012 10:55 AM
Smitty79
May 16, 2011 03:46 PM
morepower02
Feb 25, 2010 10:24 PM
