HD LED front signal install question
Old Dec 30, 2012 | 12:35 PM
nivensid's Avatar
nivensid
Default HD LED front signal install question
I am in the process of installing the HD LED front signals on my 2011 Limited. For those that have done this did you have to fish the gray/black wire for the aux lamps thru the plastic tubing that houses the wires for the signals? I have disconnected that wire from the Tyco Multilock connector in slot #4. Any pointers appreciated on how you fished the wire up thru the harness housing.
Thanks
Old Dec 30, 2012 | 12:44 PM
ripjam's Avatar
ripjam
5th Gear
I just walked it up by pushing the wire. When I did mine the wire is not as long as the conduit, so i made it exit the conduit about 3/4 the way up, looped what was there and wire tied it.
Old Dec 30, 2012 | 02:38 PM
jimclaypool's Avatar
jimclaypool
I ran a smaller wire down the tubing first and tied it to the aux gray/black wire, added a little Joy dishwashing soap and pulled it thru!
Old Dec 30, 2012 | 05:01 PM
nivensid's Avatar
nivensid
Thanks for the info, worked like a charm...
Aaron 09FXDB
Aug 7, 2020 05:48 AM
BMCsteve
Mar 28, 2018 03:18 AM
RICHIEMACK
Jan 5, 2012 10:47 PM
jarhead45
Jul 9, 2009 01:17 PM
BlockHead96
Aug 17, 2008 05:37 PM
