Wiring blinkers
Old Jan 4, 2012 | 05:43 AM
RICHIEMACK's Avatar
RICHIEMACK
Default Wiring blinkers
Ok here is what i need help with,put new joker machine led blinkers on.they have only 2 wires a poss. And neg.the old wires from the harley blinkers have 3..since it had been wired by the last owner,there is no molex to tap into ,he wired into the main harness,do i do i connect the poss or neg to thr third wire ,the third wire go to the directional button????any help
Old Jan 4, 2012 | 05:53 AM
jharanin's Avatar
jharanin
I just ran into the same issue on a XBones. The OE harness had 3 wires going to each turn signal one side had a violet, blue and black wire the other had a brown, blue and black. I messed around with different combos and found that the blue wire had no real function in regard to stop, run and turn. I have soldered all the connections and it works perfectly. I ran the violet wire to the hot side on one and the brown wire to hot on the other side and black to black...hope that helps.
Old Jan 4, 2012 | 06:01 AM
Iceman24's Avatar
Iceman24
This extra wire should be the running light function...don't think this set-up will work w/run & blink (signal only)...did they have signals w/3rd (running) wire?
Old Jan 4, 2012 | 10:57 AM
Kowan's Avatar
Kowan
Yep, two wires for signal only. Front has three stock if yours has running lights.
Old Jan 4, 2012 | 08:46 PM
UT-rckr's Avatar
UT-rckr
Hmm. Have some new Joker Machine lights front and rear that should get here next week. Ordered the Badlands Illuminator for my rears to take care of those issues. Didn't think about the front. Maybe I will just run them as turn only up front now and not running lights like they currently are.
Old Jan 5, 2012 | 08:11 AM
RICHIEMACK's Avatar
RICHIEMACK
Have the badlands 111 on the way ,hooked up just the poss and neg and it worked ,thanks guys 4 the input
Old Jan 5, 2012 | 05:32 PM
UT-rckr's Avatar
UT-rckr
Just had a thought. With a LED light with just 2 wires, could you hook up both positives and still get the running and turn lights? This is assuming the run puts out a lower signal to make a less bright light.
Old Jan 5, 2012 | 06:25 PM
jharanin's Avatar
jharanin
What are the colors of the wires on the rear turn signals? I ran two out of the three and have run, stop and tail/brake. The wiring diagram from the manual didn't even show the set up that was on my bike.
Old Jan 5, 2012 | 10:47 PM
Kowan's Avatar
Kowan
Seems as if the mount was wired as the ground on yours jharanin.
Aaron 09FXDB
Aug 7, 2020 05:48 AM
Dan Theman
Aug 8, 2011 09:55 PM
WARG
Oct 18, 2010 09:22 PM
BlockHead96
Aug 17, 2008 05:37 PM
dbpearce
Nov 8, 2006 09:20 PM
