I'd think with those narrow band 02 sensors you have a small amount of change possible if any without some type of re-mapping of the ECM.
Any change would be limited to the minimum and or maximum of what those 02 sensors are capable of 'change'.
I don't know for sure if a stock ECM has the true ability or capability to make changes automatically without being computer re-mapped? I'd think it's like a dum terminal pre-programed and has to be re-programed or re-loaded for any changes to really take effect? Simplistic...I don't know if a stock ECM can 'learn or change automatically' and if it can...then it's limited by the narrow band 02 limits it's reading.
Not to open another can of worms since so many on here you will find that have cut cats out, drilled out mufflers, replaced breathers and ride like they stole it with no problems? To each their own or whatever floats your boat?
I never had no luck with the in-line 'tricksters method' myself. Still had a lot of popping or intake burping on decel, whatever? I opted for a new ECM that I could program and or that auto-tuned. It's a pricey method but for 'myself' it's like night and day as far as I'm concerned it made huge difference all around for the better IMHO.
I chased my tail around on decel popping and intake burping myself until I replaced the ECM and went with an auto tuner. I haven't looked back and glad I did.
BTW Fuelmoto comes up a lot on here and from what I've seen you won't be disappointed with them and their selections/products and/or customer service.
Reason: wording
Now I will ask you this...I have V-Tune files that clearly show both AE & DE active while in closed loop. How can this be? Could the data be corrupt? Could the program have a fault? Could Steve, Doc, or I all be wrong by saying that sometimes, both AE & DE can be active in closed loop? Or could AE & DE ever (there's that word) actually be active even in closed loop?
Yes, they can be active and and the bike will remain in closed loop. They can also "knock" the bike out of closed loop, the de table doing it more. That is why in Doc's original vtune instructions he recommended zeroing them out to collect more data. Most people noticed much more data collected when this was done. Now they have found doing this may cause issues with the data so it is no longer recommended. On the dyno you don't disable the tables because it is so easy to move from one cell to the other, but it does blink into waiting mode when moving.
I was under the impression that in the Delphi ECM that AE and DE were active based upon throttle position changes regardless of the open loop / closed loop state. Also, O2 Sensor data is always collected as long as the sensors are in range ( enough exhaust gas present to generate a meaningful voltage). Its also interesting to note that with the 2010's and later that the maximum fuel mixture that can be maintained in closed loop is 14.34 (Not including the afore mentioned AE / DE part of the equation )
You are right with the ae and de table. They are for "transitional" fuel adjustments when moving the throttle, regardless of open/closed loop. They are active only ms. The o2 voltage is always there but the ecm only "see's" it in closed loop. On the 2010 and newer touring bike's the fuel mixture can be much richer than 14.34 in closed loop, depending on the fuel. If you were using a fuel with a stoich of 11 the richest afr you would see in closed loop would be 10.75. This is why lambda is so nice. The tuning devices that allow you to see the lambda table as an afr table can lead to a bit of confusion.
So when I go into my tts and see a setting of .977 being the lowest before it changes to open loop which fuel is it calculating against? It makes sense that changing the fuel would change these values and I would assume that this is one of the many benefits of closed loop (adapting to fuel differences between tanks) Cool! you learn something everyday!
Any fuel. The stoich of any fuel is 1. If you use the o2 sensor voltage calculator you will see that the lambda and o2 mv values will stay the same for any fuel. It is only the afr value that changes.
