The bike is a 2005 RK Classic. I removed the headlight and light bar to install a Progressive lowering drop in kit. Anyway, I'm putting everything together and I have no idea where these two wires connect. The one in the first photo is two pronged. One wire is orange/black the other is black. The other wire in photo 2 appears to be a ground. It appears to attach to a ground clip...but I can see where. I looked on the light bezel, the nacelle and even the frame...nothing.
All the lights work except the light bar.
I took pictures of everything prior to the disassembly, but as luck would have it....those are real fuzzy.
Are you sure your fender tip light works? The black clip plug with 2 wires looks to me like it's for that light.
Re: the light bar...did you try the other switch that is normally your acc? They plugs as I recall as white moles connectors, and can be interchanged. Or, are your hi beams on?
