Front Rotors Warping
Old Jan 4, 2013 | 08:13 AM
dice2010's Avatar
dice2010
Default Front Rotors Warping
Is it just me? I like to use my front brake along with my rear break on almost every stop I make. I have a 2012 ElectraGlide Classic with 9,000 miles and the front rotor is warped as I get pulsating when I sue it. My 2009 ElectraGlide Classic had the rotors replaced at about 15,000 because of the same issue. My 2005 RK had them replaced at about 18,000, same issue. Am I the only one that uses the front brake and has this warping problem? I have never seen anything mentioned on the forum about it. Does anyone else had this problem?
Old Jan 4, 2013 | 09:03 AM
glide2meetu's Avatar
glide2meetu
I have read of some problems with warping, although not an expert on it, I think others have had similar problems.
https://www.hdforums.com/forum/touri...s-warrant.html
https://www.hdforums.com/forum/touri...be-turned.html
Aftermarket rotors on this one...
https://www.hdforums.com/forum/touri...pm-rotors.html
https://www.hdforums.com/forum/touri...ed-roters.html
https://www.hdforums.com/forum/touri...ear-rotor.html
Old Jan 4, 2013 | 09:19 AM
asnowmobiler's Avatar
asnowmobiler
Mine warped with less then 3k on them, dealer replaced them without any drama. Since then, Ive been a little easier on the front brakes and havent had any issus in the 4k since.
Old Jan 4, 2013 | 09:22 AM
gvallanc's Avatar
gvallanc
I had my rotors replaced after 3000 km on a 2012 Street Glide. Vibration was so bad I tried not to use them till they were replaced. NOT IMPRESSED. Makes me think what's next
Old Jan 4, 2013 | 09:24 AM
Juan L's Avatar
Juan L
Moderator
Do you hold the brakes after a stop, as in at the stop light? I ususally try to release the brakes so I don't create "hot spots" on the rotor from the pads. The ones on your cage are much thicker and not as susceptable to this problem.
Old Jan 4, 2013 | 09:39 AM
JY Kelly's Avatar
JY Kelly
My PM Heathen rotors are BOTH warped on my 2010 SG. When I bought the bike, it had 2500mi on it. At around 3000, I started noticing the pulsing. They're unusable now. Gotta take em off and send them to California.
70% of braking is SUPPOSED to be done with the front brake. Not using it so the rotors don't warp is UNACCEPTABLE.
Old Jan 4, 2013 | 09:43 AM
Hogpro's Avatar
Hogpro
Former Sponsor
I recommend the Lyndall Carbon Composite rotors as I had really bad warped rotors on one bike and replaced them with these and have had no issues in about 8000 miles thus far. They have a lifetime warranty as well.
As far as why they warp, they get excessively hot and do not dissipate the heat as well as they should. I am a 100% front brake person. I rarely use my rear brake at all. This is how I was taught to ride by sport bike racers and it has always served me well. Id on;t think that you should have to adjust your riding style to fit the rotors. That si ridiculous, however it seems to be a fact of life. The warping is far more common on the newer bagger (09 and up) than anything 08 and earlier.
Old Jan 4, 2013 | 09:49 AM
knife_edge's Avatar
knife_edge
Do you have ABS for brakes? They do the same thing when you use them....
Old Jan 4, 2013 | 09:53 AM
casique's Avatar
casique
Try EBC rotors, not as expensive as others, but made really well. I've had great luck with them in the past and never warped a set so far.
Old Jan 4, 2013 | 10:33 AM
Hogpro's Avatar
Hogpro
Former Sponsor
The EBC's are much better as they are full floaters but we had one customer who warped a set of these as well.
