Primary Leak
Old Jan 4, 2013 | 03:58 PM
arlinsg's Avatar
arlinsg
If he is using gear oil in his transmission, give the leaking oil a good sniff.
You'll be able to tell if it's coming from the inner or outer by the smell.
Old Jan 4, 2013 | 08:17 PM
djl's Avatar
djl
A leak from the outer primary will be continuous as will transmission leaks until the fluid level drops to below the mainshaft. A leak from the inner primary will leak after a ride for a while and then stop; this leak will leave a spot the size of a half dollar or quarter before stopping.
It is unusual for the outer primarg gasket or drain plug to suddenly start leaking; just doesn't happen. Those gaskets are intened to go on dry; Yamabond, silicone sealant, shellac, etc. are not required. You should consider expanding the search for the source of the leak as has been suggested.
Time to pull the inner primary and check for leaks; check the shifter shaft seal, mainshaft seal, quad ring and mainshaft/5th gear seal. It is very common on the early models for the inner primary bearing to "walk" in on the mainshaft/5th gear seal causing a leak. If you replace one seal behind the inner primary; replace them all. If you don't find anything while in there, replace the IPB seal in the inner primary housing. I will be a six pack you find the leak.
Old Jan 4, 2013 | 08:32 PM
Rootro's Avatar
Rootro
You can buy a new inner and outer primary cover for about $500 if all else fails.
Old Jan 4, 2013 | 08:57 PM
ShadowMonster's Avatar
ShadowMonster
I would bet shifter shaft leak, unfortunately not an easy fix for a 35 cent seal........
Old Jan 4, 2013 | 09:19 PM
bagman1's Avatar
bagman1
Another thing to consider the bike is 8 years old, and without knowing the life of the bike (IE: over torqued bolts/plug, methods used in cleaning mating surfaces, and the extremity of hot/cold cycles, not to mention if something ever grenaded inside that may have created a stress fracture.) I would say its safe to figure on taking it all down and replace the seals and have the mating surfaces checked. Doesnt the 05's still use the round gasket in the center of the cover at the inspection cover bolts? If so this cold be where it maybe coming from.
Old Jan 5, 2013 | 06:54 AM
Stew Pidaso's Avatar
Stew Pidaso
Thumbs up
Originally Posted by jamesw
Sounds like an inner primary bearing seal leak.
That often runs down the back of the inner primary, and runs to the low point to drip, and looks like a leak from the outer primary.
+1 . This was the problem I had with my '09 SG. Drove me batty until I took it to my Indy. Was primary out put main bearing.
Old Jan 5, 2013 | 08:18 AM
jus2anoyu's Avatar
jus2anoyu
If someone overtightened the drain plug, the primary cover may be cracked. Good used ones can be had on eBay for a few bucks. That would be my next move given the information...
Old Jan 6, 2013 | 09:19 PM
Watchfuliz's Avatar
Watchfuliz
Originally Posted by Streetrunner
I just had a similar problem fixed. The oil was leaking from the shifter arm which made it look like it was coming from the primary. This is a very common leak.
+1 on shifter shaft seal. That is a common problem.
JONNIEROCK
Apr 18, 2016 04:14 PM
harleyheaven
Jun 27, 2012 08:55 PM
redman53
Jul 16, 2011 04:59 PM
Doug S
EVO
37
Mar 18, 2010 04:26 AM
Helitrash
Jul 31, 2008 10:04 AM
