accessory power
Old Jan 4, 2013 | 01:08 PM
Chopman's Avatar
Chopman
Default accessory power
I am in the process of hooking up the saddle bag lid spoilers and have also just purchased a heated seat of rthe wifes 2009 street glide.
The Harley spoiler directions and kit show how to plug in the pig tails to the accessory plug by the battery.
My question is can i utilize the Harley power splitter in the catalog and tie in the power for the seat as well as the spoiler power so that the seat power is only on when bike is powered
thanks
Old Jan 4, 2013 | 01:13 PM
mkguitar's Avatar
mkguitar
hmm, you should check with the dealer, that way if there is a problem you might have some recourse.
anything heated draws a fair amount of power.
if it were me, I'd wire the seat to a relay which is fed from the battery with a fuse inline- and allow the stock wiring to trigger the relay.
i work with electronics, so that is what I'd do.
if you are not familiar or comfortable wiring, pose your question to the dealer.
FWIW I have rewired the rear on my 09 to suit my needs, added some stuff, took some stuff off... used flat type trailer connectors ( with leds) for my detachables- these are cheap, weather resistant, durable and available at any auto parts store
on my old evo, I rewired the front lighting to use a new fused feed wire and relays, to allow high current lighting ( 220 watts total) with out stressing the stock wiring or the weak link ignition switch
mike
Old Jan 4, 2013 | 01:45 PM
AnotherBlackSG's Avatar
AnotherBlackSG
Yeah, what he said.
Old Jan 4, 2013 | 02:54 PM
vistavette's Avatar
vistavette
How does Harley recommend you wire the seat?
wildrooster
Feb 5, 2025 10:45 AM
Captnpirate
2014-2024 Touring Models
Oct 9, 2015 09:38 PM
buellrider76
Apr 10, 2015 08:34 AM
Taranwanderer
May 24, 2014 12:38 PM
waltr
Mar 19, 2007 01:56 AM
