Buy the HD service manual for your bike;the wiring diagrams show color coded wiring for the circuits; and decide if what you have is OEM or other.
Already have a manual..Definitely not OEM..hopping someone could of helped me out before I had to chase wires but I guess thats what Im doing this weekend!
I'm thinking either a remote garage door opener or maybe a proximity sensor for the alarm system??? Does the light blink all the time or only when you're close to the bike? Does it blink at a steady rate or does it vary?
What wires does it hook into in the factory harness?
I was looking at it again today and it seems that movement does not cause it to blink it just blinks all the time. It has a red light that blinks at a pretty constant rate and then a green light above it that is more random. I tried tapping on it and moving it upside down and it did not seem to change the rate of blinking.
I am thinking its part of a old security system so Im afraid to remove it in case it would cause the bike not to run
I am guessing it is some kind of mercury switch which might be activated when the bike is either tampered with (moved) or when the bike leans a certain amount.
