help , fork brg access
Old Jan 10, 2013 | 10:28 AM
raw's Avatar
raw
Default help , fork brg access
How do you get to the fork bearing adjusting nut on a 07 road glide.
Do you have to remove the fairing?
thanks.
Old Jan 10, 2013 | 11:34 AM
Def Mute's Avatar
Def Mute
Yes, you do...
Right after you purchase a service manual.
Old Jan 11, 2013 | 04:10 AM
grbrown's Avatar
grbrown
Talking
Originally Posted by Def Mute
Yes, you do...
Make that a factory service manual! It will tell you all you need to know and help you get through any sleepless nights.....
Old Jan 11, 2013 | 04:30 AM
jus2anoyu's Avatar
jus2anoyu
Snap-on makes a very nice tool to move the preload spanner. Only about 20 some odd dollars and it makes the adjusting process MUCH easier.
Old Jan 11, 2013 | 04:33 AM
ardakota's Avatar
ardakota
I just used a little allen wrench to turn mine just the other day worked good for me.
Old Jan 11, 2013 | 04:35 PM
raw's Avatar
raw
I have the service manual, I was just wondering if I could access it without removing the fairing....thanks
Old Jan 12, 2013 | 05:54 AM
grbrown's Avatar
grbrown
Wink
There are no short cuts!
Old Jan 12, 2013 | 07:47 AM
scj's Avatar
scj
You DO NOT have to remove the fairing to adjust the steering neck bearing tension on a Road Glide.
Remove the key lock along with the speedo and tach assembly plus take the handlebars loose. You need to loosen the bottom fork tube pinch bolts so as not to bind the triple trees when you tighten the bearings as well.
Old Jan 14, 2013 | 11:22 PM
Def Mute's Avatar
Def Mute
I stand corrected...
jf7689
EVO
Feb 22, 2018 10:24 PM
BKSinAZ
Jun 9, 2015 04:02 AM
hogdvr
Dec 12, 2008 09:39 PM
George_thesing
Apr 20, 2008 08:46 PM
RicksFlhti
Nov 25, 2007 02:05 AM
