looking for cam swap tips
Old Jan 16, 2013 | 08:35 PM
hawwk's Avatar
hawwk
Originally Posted by senna
I did mine without removing the oil pump. The cam plate is on dowels and the crank is not going anywhere. So what is there to align?
Thanks. This is what I thought but figured it as better to ask fisrt.
Old Jan 16, 2013 | 08:38 PM
03dragonRK's Avatar
03dragonRK
Originally Posted by aktid35
Buy the set of spacer washers from Harley has any size you would need. If going in the top buy low clearance ratchet from Georges garage. Never seize is your friend for reinstalling your exhaust.
+1 on the spacer kit. With the TW222 cams you will need to use adjustable pushrods as the base circle is different then the stock cam and you can't use the stock pushrods.
Old Jan 16, 2013 | 10:46 PM
the warden's Avatar
the warden
Originally Posted by KSGLIDEGUY
. Great advice everyone. I watched the youtube video and plan to have my laptop in the garage so I can use it as a reference. Dumb question though. Do you need to drain the oil before starting this?
I watched this video a dozen times before I did my 222s and also had it in the garage when I did the swap. Make sure you have the right tools, bearing puller/installer, good quality torque wrench, tappet magnets etc, and take your time. The FM pushrods were a pain, but here again, TAKE YOUR TIME, you need to get the pushrods installed properly and the adjustment just right. If I were to do it again, I would go with the S&S quickie pushrods. If you are mechanically inclined at all you will have no problem.
Old Jan 17, 2013 | 05:49 AM
Notgrownup's Avatar
Notgrownup
I didn't screw with the oil pump at all. I used SE quick install Pushrods from the advice of many here and my Indy.
psoff
Milwaukee Eight (M8)
Aug 25, 2018 03:44 PM
Bikerscum
2014-2024 Touring Models
Jun 7, 2015 09:53 PM
05dlx
13
May 27, 2015 07:25 PM
Rhetor
Exhaust System Topics
Jun 29, 2011 04:43 AM
bikerlaw
EVO
May 27, 2010 02:14 PM
